So I have a random 92mm fan that someone gave me, hooked up to a random wall wart from god-only-knows-where as a sort of a desk fan. Power switch is from an AT system. LOL.
Wall wart is a "Hon Kwang" DC12-50, rated 12v 500mA output.
Fan is a SproFan SJ-92X12A, rated 12v 150mA input.
After an hour or so of steady fanning, the wall wart is hot enough to fry bacon on. It's not quite literally painful to pull it off the power strip, but if it gets much hotter, it will be.
Is that something I should worry about? will the heat kill the wart? (and if so, will the dying wart kill the fan?) or is it just fine if not expectable for a cheap wall wart to heat up significantly during use?
