clivebuckwheat
- Feb 21, 2004
Hi
At work we have about 250 pc's with intel 10/100 pro ve on board nic card with the ability to WAKE ON LAN.
My problem is if i do a start ==>shutdown the next time i try to use wake on lan it will work ok
but if i shut down with the power button, and if i then try wake on lan it will not work.
This is a problem because I work in a school with 8000 plus students and they all use the power button.
what is wrong with the WAKE ON LAN.
