craigdt
- Oct 27, 2016
American cars did this. Governors is what we used to call them.
I’d just disable it like we did in the 1990s.
Great idea but good luck since it's probably all electronic bs.
I've had a vehicle up to 140 mph, for a very short amount of time, on a deserted section of interstate with no one else around. most people in the united states will never get a vehicle that fast even on a track. It's only been in the last decade with developments in engine tech like direct fuel injection that small engines in production cars could develop the horsepower to get even close to that.
My old Chevy Beretta was also limited to 90Mph and I still have the car but don't drive it. Back in the day I got around it with a new chip that eventually blew up and took out ECU's. That was an expensive discovery.Yeah, my '97 Mercury Sable was governed at about 120Mph.
Fuel injection had been around in Mass produced cars since the early 80's.
Back in 2004 I was radared going 168mph (where my 5th gear bounced off the rev limiter) in a 50 zone in my heavily modified manual transmission Saab 9-5 Aero.
Younger me did irresponsible things. That was a bad day.
But we are not the norm. Most people never try. I've heard people be *shocked* that I would ever even consider driving 90mph.
it's a joke. didn't think I had to put a /s on something as obviously silly as that.
A 2004 Acura TL could go over 150 MPH? if you dropped it from an Airplane, perhaps.
2002 TL-S auto
C/D ESTIMATED PERFORMANCE:
Zero to 60 mph: 6.9 sec
Zero to 100 mph: XXXX
Street start, 5-60 mph: XXXX
Standing ¼-mile: 15.1 sec @ 94 mph
Top speed (drag limited): 145 mph
Braking, 70-0 mph: XXXX
Roadholding, 300-ft-dia skidpad: XXXX
the CLS was slightly faster at 146 so...
Zero to 60 mph: 6.8 sec
Zero to 100 mph: 17.3 sec
Street start, 5-60 mph: 7.0 sec
Standing 1/4-mile: 15.2 sec @ 93 mph
Top speed (governor limited): 146 mph
Braking, 70-0 mph: 191 ft
Roadholding, 300-ft-dia skidpad: 0.82 g
seems to be some confusion on C&D drag or governor limited as the owner of a 2002 CL type S for 10 years I can say with certainty that the car was indeed governor limited as top speed was obtainable in 4th and 5th gears and the car just stops accelerating abruptly when you reached 148 (GPS speed) engine speed was roughly 4300-4600 depending upon gear...
the unmodified car was rated at 270hp, respectable for a 6 cylinder at the time, I suspect it's drag limited, it gets very difficult to go faster at a certain point, no matter how much HP you throw in a car. My 2016 Mustang GT was rated at 435 hp, drag limit on it was around 170 mph, electronic limit was 155.
a 1990 ZR-1 could do 170 and it had only 375 hp in 1990....so either your stang has a lot of drag or it is weak sauce in the HP department or most likely electronically limited.
https://www.roadandtrack.com/new-ca...1990-chevrolet-corvette-zr-1-drive-flashback/
like I posted "170 mph drag limited"
A corvette is a much lighter car with less drag. it's not a fat ass family sedan with a huge front end like an Acura. more than just raw HP is involved in top speed calculations.
The S60 is made in China now, not Sweden.. From what I remember.Probably should have RTFA. Alright but now that I did am I reading this wrong?
“It said the electronic restriction focused on driver behaviour because mechanical solutions alone could not ensure safety. The limit will apply to all cars made from mid-2020 onwards.”
I was actually looking at an S60. This is disappointing.
This is what a slight bump in the road does at 200mph:This pansy shit makes me sick. If the vehicle has enough power to do high speeds it doesnt take very long to get there. I have been over 200mph on public roads so many times that I think I went back in time.
And to the person that said a pothole at anything over 85 can cause fatality, eeeehhhhhhhh, unless there was a recent sinkhole or something a standard pothole will cause more problems at 55 than over 100.
Again, there are areas of the country where -
You don't see anyone for long periods of time
Even if you saw a cop, they wouldn't give a shit if you were going 120
If your car can do it safely, why not?
No, you don't need to drive over112 in these areas, but you are literally just wasting your time if you aren't and you have a vehicle that can handle it.
Because we as a society have decided that YOU dont get to make up your own safety parameters on the fly.
So what is the drag coefficient on a 90 ZR1 vs. a 16 mustang? I'm guessing the former has a significant advantage there. Though apparenlty, it is a lot heavier than I thought.
I'm completely with you on this and reject the safety nazi nanny state crybaby way of looking at this issue.Good thing that I don’t have to listen to YOU.
If I want to fly off the road at 120mph miles away from the nearest human being that’s my choice.
I had to make the west texas into new mexico drive quite a bit. There is a section there where you can go a few hours and not see a single other car on the road. If your vehicle will do 100+ safely there is no reason not to do it.
I remember driving 1-10 back when the speed limit was 55. talk about agony.
EDIT: and I suspect you are talking about route 54... yeah, it was deserted back then too.
You can't drive 55? lol
EDIT: made me think of sammy hagar
Currently. It could be changed in the future such that it becomes harder to flash the ECU. Other companies have made it difficult. Dodge for example. Let's hope they don't lock us out. Ford still allows it but they can tell if it's been flashed and will try to void the warranty because of it.If there's a Volvo tuning community, they'll circumvent this using whatever tools they have to manipulate the ECU via the diagnostic port. At least that's how it works in Subaru land.
Hard to argue with any of that. 100+ mph, if the car leaves the road, you are in bad shape.I appreciate the idea of driving fast, but the risk/reward skews way too hard to risk in this case.
I don't presume to make the choice for others, as long as they do it away from traffic and people.
I was wondering the same thing. Why 112 and not 110 or 115.
Yeah I'm aware of that one lol, but that wasnt bought new and tracked, nor is it stock lol. I mean not that you can't, but there much better options if you want to go to the track on the weekend than a volvo, and really a used car you can setup properly is the best option.
