I recently put together a system with a (cheapo) ECS 945GCT-M/1333 mobo, Intel C2D E7200, GeForce 8800GS, and a 480W Antec TruePower II power supply. While trying to troubleshoot some issues with the computer acting weird on occasion when it powers on, I noticed that the +12V rail runs from 13V-13.4V, and the +5V rail runs around 5.4V or so. I know this PSU has 2 +12V rails but I don't know how they are separated; I tested one of the Molex connectors as well as one of the PCI-E videocard connectors and got the same results.
Is this something that I should be concerned about? There isn't a lot of stuff in this system: only the 65W C2D processor, 8800GS videocard, 2 hard drives, DVD+RW drive, and 2 casefans. Is there anything that I might be doing wrong that would cause this? This is the first PC I've built myself in a couple of years, so I don't know a whole lot about how all the newer power supplies work. There is only the 24-pin mobo power connector and the 4-pin +12V connector on the board...given that this is a cheap ECS board might the lack of proper connectors have something to do with it? I remember I helped my brother build an Athlon X2 system not too long ago and that it had an 8-pin connector on the board.
Any advice would be greatly appreciated! thanks
