GreatestOne
- May 15, 2005
Hey guys... I want to undervolt my Sapphire 7950's, all models. Seems like it is impossible to do it on BAMT Linux from what I've read. If I am mistaken please let me know how.
Otherwise, are voltage changes made to the actual hardware itself, permanently? Meaning what if I install it into my Win7, use TriXX to undervolt, and then put it back into BAMT, will that work without complications?
Also, is there a difference between using TriXX or flashing the BIOS for this process?
This was a BIOS someone suggested:
http://www.techpowerup.com/vgabios/114948/sapphire-hd7950-3072-120116.html
Thanks.
Thanks.
