VNC Connection to DMZ through pfSense
Hi All,
New to these forums, so hopefully I've got the correct subforum! :)
I'm running pfSense at home to protect my Personal network (which connects via AirVPN for the internet).
However on the other side of this firewall is my family's home network, in which is a windows machine running TightVNC server.
I need to poke a hole from my Personal network, through the pfSense box and straight to this server, I suspect some of the routing might need tweaking too.
My Personal Network (LAN) is on : 192.168.1.0/24
My Family's Network (DMZ) is on : 192.168.0.0/24
The TightVNC server static IP is: 192.168.0.10
pfSense LAN (Personal Network) IP: 192.168.1.252
pfSense WAN (Family Network) IP: 192.168.0.252
ISP Gateway (Family Network) IP: 192.168.0.253
At the moment, pfSense is routing all valid traffic that is not on my Personal Network out over the VPN. There are rules in place to stop things going out that shouldn't.
Could someone more knowledgeable than I, advise what I need to change (at the moment I can't even ping the VNC server) in order to get this to work?
Many Thanks
Jon
Just for clarification, I've attached a pic of my network setup.
I can't ping or otherwise access anything in the DMZ from the LAN (except strangely my Internet GW box - both ping and the webui)
I'm obviously missing a pass rule somewhere but it's eluding me.
Cheers
Jon
bman212121
I don't actually see a rule in any of that which would allow it to work.
If you're going from anything internal to anything else internal, you are probably not using NAT. So none of those outbound NAT rules mean anything for what you are trying to accomplish.
The only thing you need to do to make this work, is add another rule under firewall > Rules > LAN. You want a rule that says your source address of LAN Net (meaning lan subnet) can talk from any source port (since it's randomized) to a destination of the DMZ IP address of that server, on port 5900. Off the top of my head I can't remember if that's TCP or UDP, so when it doubt I just use both.
It should look something like this:
I chose 192.168.0.10 as the single host that the rule allows traffic to flow to, but you can pick any IP that you need.
The config screen should look like this:
(Ignore the comment for OPT1, in your case that will be DMZ)
FYI that still won't let ping work, but you can put in another rule that says source LAN Net, destination DMZ Net, and Protocol ICMP. That will allow any PC in the Lan subnet to ping any PC in the DMZ subnet, but not the other way around.
Thanks bman,
I added the rule as suggested (makes sense to me), but still can't connect.
I tried broadening the rule so anything on LAN could see anything on the DMZ;
This didn't work, I have 0 access to the DMZ apart from the GW.
Something else is missing I think.
Edit: More accurate network diagram below (not that it really changes anything)
Cheers
Jon
Dawizman
Is the pfsense box the default gateway for the devices on your family's network?
If not, you will need either a static route in either their router, or their devices, or you will have to setup an outbound NAT rule.
Thanks Dawizman,
These are my current outbound NAT rules;
So if I'm understanding correctly, I need a new rule on the LAN interface allowing traffic from LAN net to DMZ net? (restricting to port 5900 for VNC if needed?)
Would that be in conjunction with the LAN rule I created earlier or instead of it?
Cheers
Jon
Yep, adding the Outbound NAT rule for 192.168.1.0/24 to 192.168.0.0/24 on the DMZ interface did the trick.
Thanks guys for you help!
Jon
