Chrisroman
- May 29, 2011
Pretty much everything you guys talk about over here is over my head, so your smarter than me about all this... maybe you can help me out
Host: Win 7 x64 Pro (Specs in signatures)
Guest: Win 7 x64 Pro (Config file below)
I moved my "work" setup to a VM and everything is working great except for the softphone. I am using Toktumi softphone with a Jabra 9470 Pro USB headset. The headset audio and mic, within the VM, are clear except when using the softphone. When using the softphone, audio is garbled. I havn't even tried to test the mic with it yet. I havn't been able to find much on using softphones within VMware workstation. I found a few threads regarding Skype that were nonconslusive and some references to SIP soft clients being hit and miss within the VM. But nothing to help me troubleshoot.
Any ideas? I know I can run the softphone on the Host system, but I want to keep the VM completely self contained.
P.S
I did disable memory paging and trimming. My hardware, despite being an old X58 does support VT-x, which is set to "Automatic" in VMware.
VMware Workstation 9 Config File
P.S
Code:
.encoding = "windows-1252"
config.version = "8"
virtualHW.version = "9"
numvcpus = "1"
cpuid.coresPerSocket = "1"
scsi0.present = "TRUE"
scsi0.virtualDev = "lsisas1068"
memsize = "6144"
mem.hotadd = "TRUE"
scsi0:0.present = "TRUE"
scsi0:0.fileName = "Windows 7 x64 - Work-000007.vmdk"
ide1:0.present = "TRUE"
ide1:0.fileName = "auto detect"
ide1:0.deviceType = "cdrom-raw"
floppy0.fileType = "device"
floppy0.fileName = ""
floppy0.clientDevice = "FALSE"
ethernet0.present = "TRUE"
ethernet0.virtualDev = "e1000"
ethernet0.wakeOnPcktRcv = "FALSE"
ethernet0.addressType = "generated"
usb.present = "TRUE"
ehci.present = "TRUE"
ehci.pciSlotNumber = "35"
sound.present = "TRUE"
sound.virtualDev = "hdaudio"
sound.fileName = "-1"
sound.autodetect = "TRUE"
mks.enable3d = "TRUE"
serial0.present = "TRUE"
serial0.fileType = "thinprint"
pciBridge0.present = "TRUE"
pciBridge4.present = "TRUE"
pciBridge4.virtualDev = "pcieRootPort"
pciBridge4.functions = "8"
pciBridge5.present = "TRUE"
pciBridge5.virtualDev = "pcieRootPort"
pciBridge5.functions = "8"
pciBridge6.present = "TRUE"
pciBridge6.virtualDev = "pcieRootPort"
pciBridge6.functions = "8"
pciBridge7.present = "TRUE"
pciBridge7.virtualDev = "pcieRootPort"
pciBridge7.functions = "8"
vmci0.present = "TRUE"
hpet0.present = "TRUE"
usb.vbluetooth.startConnected = "TRUE"
displayName = "Windows 7 x64 - Work"
guestOS = "windows7-64"
nvram = "Windows 7 x64 - Work.nvram"
virtualHW.productCompatibility = "hosted"
powerType.powerOff = "hard"
powerType.powerOn = "hard"
powerType.suspend = "hard"
powerType.reset = "hard"
extendedConfigFile = "Windows 7 x64 - Work.vmxf"
scsi0.pciSlotNumber = "160"
ethernet0.generatedAddress = "00:0c:29:6f:c6:ef"
ethernet0.pciSlotNumber = "33"
usb.pciSlotNumber = "32"
sound.pciSlotNumber = "34"
vmci0.id = "577750767"
vmci0.pciSlotNumber = "36"
tools.syncTime = "FALSE"
uuid.location = "56 4d 99 80 39 74 7a 6d-dc 3c 1b fa 22 6f c6 ef"
uuid.bios = "56 4d 99 80 39 74 7a 6d-dc 3c 1b fa 22 6f c6 ef"
cleanShutdown = "TRUE"
replay.supported = "FALSE"
gui.lastPoweredViewMode = "fullscreen"
unity.wasCapable = "FALSE"
replay.filename = ""
scsi0:0.redo = ""
pciBridge0.pciSlotNumber = "17"
pciBridge4.pciSlotNumber = "21"
pciBridge5.pciSlotNumber = "22"
pciBridge6.pciSlotNumber = "23"
pciBridge7.pciSlotNumber = "24"
scsi0.sasWWID = "50 05 05 60 39 74 7a 60"
usb:1.present = "TRUE"
ethernet0.generatedAddressOffset = "0"
tools.remindInstall = "TRUE"
vmotion.checkpointFBSize = "134217728"
softPowerOff = "TRUE"
usb:1.speed = "2"
usb:1.deviceType = "hub"
usb:1.port = "1"
usb:1.parent = "-1"
floppy0.autodetect = "TRUE"
ide1:0.autodetect = "TRUE"
checkpoint.vmState = ""
usb.autoConnect.device0 = "path:1/3/3/0 autoclean:1"
floppy0.startConnected = "FALSE"
usb.autoConnect.device1 = ""
vhv.enable = "FALSE"
usb:0.present = "TRUE"
usb:0.deviceType = "hid"
usb:0.port = "0"
usb:0.parent = "-1"
MemTrimRate = "0"
