Vista64 driver signing
Discussion in 'Operating Systems' started by cwolf78, Apr 15, 2008.
  1. cwolf78
    cwolf78 Limp Gawd
    456
    May 7, 2005
    Is there a way to disable driver signing enforcement in Vista64 ? Thanks !
  2. vaca232
    vaca232 [H]Lite
    96
    Dec 21, 2006
    I think there's an option for that in the startup options, where you select safe mode and things like that. Somebody else who knows more will respond soon I'm sure..
  3. Kangg
    Kangg Ad Blocker - Banned
    1,996
    Jun 8, 2004
    You can either turn off UAC or hit f8 on startup to temporarily disable driver signing.
    It's just like picking safe mode only 1 of the options is to disable driver signing. The f8 way is only until the next time the machine reboots though.
  4. cwolf78
    cwolf78 Limp Gawd
    456
    May 7, 2005
    Where is the UAC 'on/off switch' located ? That sounds like the fix I need... I don't want to have to f8 everytime I reboot.
  5. vaca232
    vaca232 [H]Lite
    96
    Dec 21, 2006
    It's in the User Accounts control panel
  6. cwolf78
    cwolf78 Limp Gawd
    456
    May 7, 2005
