digital_exhaust
[H]ard|DCer of the Month - May 2008
- Aug 14, 2006
The proper path for the tray client is this: C:\Users\*your user name here*\AppData\Roaming\Folding@home-gpu\
Took me a while to figure that out, but since I did FahMon has been monitoring it perfectly.
It's the tray client... I think I should probably go with the console client... Have you had any problems with it so far?
Another thought... I do have UAC enabled (I personally have no problem with it) but do you guys think that might be an issue? When I launch FAHMon, I have to right click and run as administrator to get it to open...maybe disable UAC and see if that solves the problem...
I haven't had a single GPU unit fail on me. Definitely can't say that for the SMP client though.
