Vista ?: UAC Disables Network Connection
westrock2000
I reinstalled Vista after an upgrade and afterwards my Network Access shows to be denied and the little icon in Task Manager has an X over it.
I can still surf the web, but I cant download anything. If I try to download anything, its just sits there saying contacting server then times out like the link was invalid.
I turned off the UAC and everything works perfectly (network icon is good, can download), but I would prefer to keep the UAC on.
criccio
Fully Equipped
Hmm. With UAC on and you are connected the the internet, open a command prompt and type "ipconfig /all" without the quotes. Paste the results here.
