RESTfulADI
- Feb 20, 2005
I need help. Just installed Vista and my FW900 is stuck at 60hz in most resolutions. Forceware 163.11 doesn't have an option to create custom resolutions. I have tried RefreshForce and RefreshLock (both work great in XP) and neither of them work, even if I "run as administrator". Also tried Rivatuner override and I can't get it to work, and Powerstrip doesn't even let me click the "Advanced Timings" button. I tried installing the FW900 driver and no help.
This is really pissing me off because I finally got everything else to work fine from nvidia drivers, creative drivers and alchemy!, mouseware even works if you install it in "xp sp2 compatibility mode" (I need 800dpi on my mx510). I'm used to playing games at 95-140 hz on this monitor and there is no way I am going to settle for 60hz.
Another problem is that I since ReForce does absolutely nothing, I have no way to add 1440x900, which is a great compromise resolution when 1680x1050 runs too slow.
Does anyone know how to successfully override refresh rates and create custom resolutions in Vista because I am about to go back to XP.
