vista media center 360 beta test
Discussion in 'General Gaming' started by JonnyK, Jun 1, 2006.
  1. JonnyK
    JonnyK 2[H]4U
    2,216
    Jul 3, 2004
  2. zero002021
    zero002021 [H]ard|Gawd
    1,317
    Dec 29, 2004
    I signed up, let's see what happens.
  3. theNoid
    theNoid [H]ardness Supreme
    7,438
    Dec 23, 2003
    Sweet! Thanks for the link, I signed up :D
  4. Klintor
    Klintor Limp Gawd
    379
    May 6, 2006
    Welcome to two weeks ago.
    But, yeah...
    I still signed up. :D
  5. ThirtySixBelow
    ThirtySixBelow Gawd
    846
    Dec 4, 2004
    0M6!! oLD n3WZZZ!!!!!
  6. killedaway
    killedaway Limp Gawd
    314
    Feb 16, 2006
    weak. everyone else apparently has known about it. i go click it right now, and i'm assed-out...
    TEEEEERIFFIC.
  7. Arkanian
    Arkanian [H]ard|Gawd
    1,667
    Feb 8, 2004
    From Website:
  8. SC385
    SC385 [H]ard|Gawd
    1,333
    Jun 14, 2004
    so if i were to try vista beta 2 with the 360 it wouldnt work right now as a media center extender?
  9. hungryduck
    hungryduck [H]ard|Gawd
    1,531
    Mar 29, 2005
    try it and find out
  10. R1ckCa1n
    R1ckCa1n [H]ardness Supreme
    4,355
    Jul 22, 2004
    Yes it will work as a media extender. M$ seemed to pick the applicants that had a 360 because this is the "HUB" for their digital living room. Works great so far.
  11. Staples
    Staples [H]ardness Supreme
    7,828
    Jul 18, 2001
    I signed up for it a week ago. I want to know when the acceptance mails are sent out.
    I am really disappointed on how terribly the 360 works off Media Center. Hopefully it will work better with Vista.
  12. Blauman
    Blauman [H]ard|Gawd
    1,550
    Jul 27, 2004
    It is now full and closed :(
  13. MasterShredder
    MasterShredder 2[H]4U
    2,998
    Jan 3, 2002
    Are you serious? What don't you like about the 360 + media center? I think it works fantastic and haven't had any issues since I started using it...
  14. Arkanian
    1,667
    Feb 8, 2004
    ^prob a training issue
  15. Staples
    7,828
    Jul 18, 2001
    Try rewinding a video. This does not hold a candle to TIVO.
    Since the dashboard update, you are now able to rewind and ff game trailers and it works just as poorly.I now conclude what I suspected earlier, WMV is just very limited. Apparently it is not easy to FF or rewind. I figure it needs calculate the data from the previous ten frames to get the picture for the tenth frame making rewind very very CPU intensive. Whatever TIVO does, it does it great for searching a video.
    I don't think this will change with Vista. MS just needs a faster video codec.
  16. Tetrahedron
    Tetrahedron [H]ard|Gawd
    1,579
    Jun 24, 2004
    I was using the Vista beta 2 Media Center with the 360, though I switched back to Windows MCE 2005 with rollup 2 since transcode360 (to stream divx/xvid videos) doesnt work with the Vista beta 2 Media Center.
  17. Kersk
    Kersk Limp Gawd
    129
    Jun 22, 2003
    Bah, I was hoping the big feature that they were holding out on to get everyone to upgrade to vista was divx/xvid support.
    "Upgrade to vista! All of your pirated tv shows will work now!"
    Oh well, thank god for transcode 360 :_x
  18. squeezee
    squeezee Limp Gawd
    504
    Aug 6, 2005
    WMV is about the same in terms of performance as most MPEG4 variants, such as Divx/Xvid/H.264 which is to say it requires more processor power than MPEG2 which is used in your TIVO. The Xbox360s cpu should be more than adequate to playback/fastforward/rewind WMV video even WMVHD content, i'd suspect its the dashboard software that is poorly coded/optimised.
  19. MasterShredder
    2,998
    Jan 3, 2002
    I never rewind or FF.. I just skip ahead and back. It's faster IMO.
  20. Staples
    7,828
    Jul 18, 2001
    The only problem is that skipping is in 30 second intravels. I wish you could set it to skip by 5 minutes or so. Maybe they will add this in the future.
  21. Tetrahedron
    1,579
    Jun 24, 2004
    yes thank god for transcode360 for MCE'05 but curse god for not allowing transcode360 to work with the vista MCE :(
