I am taking a look at a Dell laptop for a friend. They were 'downloading' iTunes (i'm not sure if they were actually downloading or trying to install iTunes) and their laptop froze. On restart they got the 'computer was not shut down correctly' menu, and starting up in safe mode (w/ command prompt or w/ networking or normally) brings a blank screen with just the mouse pointer visible.
The mouse pointer responds to touchpad movement. The windows splash screen shows, and when the screen saver comes on it is visible. This means it is not a graphics issue. Ctrl-Alt-Delete and Ctrl-Shift-ESC have no effect.
I have seen several posts about this online but with no real solution for the ones that the task manager is not accessible.
Any Ideas?
Laptop is a Dell Inspiron 1525. OS is Vista. I have the recovery disk and am able to load repair features and a command prompt.
I have tried onboard hardware diagnostics, system restore, last known good configuration, and hooking up to an external monitor.
Any Ideas?
