Moogle Stiltzkin
- Nov 11, 2004
I just recently read some other Vista SP1 64bit user and they reported the following.
http://luminous-landscape.com/forum/index.php?showtopic=25185&st=0
Could this explain why sometimes my calibration results are different when i review with basICColor after a while even though i didn't change any settings or done any calibration ?
Any ideas ?
My tuppence worth..........
Since loading SP1 on my Vista Ultimate64bit system, I cannot retain a monitor profile.
I am using an EyeOne Match2 with basICColor Display using presets and the Express mode of profiling.
After profiling, everything looks fine. However, after either succumbing to the Authorization Bug (as outlined in the article in the above link) or rebooting, Vista fails to load the profile. In System Profile, the profile is listed as the default profile, but that is not the case. I have basICColor grey test strips permanently on my desktop and I can tell immediately when the profile goes awry.
I have turned off the nVidia startup items AND disabled the Firewall, all to no avail.
SP1 is a crock, as far as I'm concerned. Yes, Vista is very stable and CS3 screams along on this very fast computer (I can save out a 220Mb Hasselblad TIFF in 13 seconds and the Retouch Artists' Speedtest takes only 22 seconds.), but this profiling problem is a major pain.
Any other suggestions?
Thanks.
Any ideas ?
