McRackin
- Dec 27, 2008
Whats the diff between 32b and 64b vista?
ps. im a noob with XP for the past 7 yrs
So what you're saying is someone with a simple quadcore processor and 4gig ram it makes maybe 5% performance difference?
Probably something like that. Vista x64 does run faster than 32-bit though, so you may as well go with it if you have a 64-bit-capable CPU unless you need to run a particular application that isn't compatible.
If not, ir really doesn't matter which one you use - there is practically no other difference between them.
For example, if all you use on your computer is Notepad, and you have 512GB of RAM, .
For example, if all you use on your computer is Notepad, and you have 512GB of RAM, you're probably fine.
I read in some forums overclocking in 64bit is a bit more difficult, because the cpu needs more vcore to stabilize it compared to a 32bit OS. Currenty running Vista 64 and I find it a bit believable.
Just bought a new harddisk, and I'll install a windows 7 beta x32 just to check.
Overclocking and the OS you're running have nothing to do with each other.
The only limit on overclocking is the hardware involved and the cooling, that is all
