VisionTek RX 570 Dual Fan OC 4GB - DVI Port?
multi-tasking_guy
i got this VisionTek video card that has 5 ports: 3x display port, 1 x hdmi, 1 div
i tried to setup 3 screens using the following ports: 1 display port, 1 hdmi, 1 div
but the dvi port does not seem to be working, i tried different variations using the dvi port
yes, i know i can use the other ports, which i tested, and they all work fine, for a total of 4 monitors
but i really wanted to use dvi port instead so i wouldn't have to buy another displayport adapter
i can't find any documentation online on this card, whats up with the dvi port not working, why is it even there
i have another rx 570(but different manufacturer ) and i can use the dvi port
heres all the info on the card
VisionTek RX 570 4GB - Dual Fan OC
OV - 570R4LC No.:OV - 570R4L VB.0
160430HJB
Code:
Graphics Card Manufacturer - Built by AMD
Graphics Chipset - Radeon RX 570 Series
Device ID - 67DF
Vendor ID - 1002
SubSystem ID - 0B31
SubSystem Vendor ID - 1002
Revision ID - EF
Bus Type - PCI Express 3.0
Current Bus Settings - PCI Express 3.0 x16
BIOS Version - 015.050.002.001
BIOS Part Number - 113-P20-XL-O1264M7G-W82
BIOS Date - 2017/04/14 03:59
Memory Size - 4096 MB
Memory Type - GDDR5
Memory Clock - 1750 MHz
Core Clock - 1264 MHz
Total Memory Bandwidth - 224 GByte/s
Memory Bit Rate - 7.00 Gbps
2D Driver File Path - /REGISTRY/MACHINE/SYSTEM/CurrentControlSet/Control/Class/{4d36e968-e325-11ce-bfc1-08002be10318}/0000
OpenGL® API Version - 4.6
CruisD64
Does the DVI port work when plugged in by itself? If so, try that and add monitors one at a time. If it stops working after plugging another one in, it's possible only one of the ports work simultaneously. I'm just guessing at that, but who knows.
multi-tasking_guy
it doesn't work when plugged in by itself
it doesn't work at all. almost like it's dead
my other rx 570 dvi detects it right away
