proggm
- Jul 14, 2016
Hi! New member here (used to be in xtremesystems, now offline sadly).
Years ago I adopted a three-year cycle on system upgrading (to the highest-end components available). Last time I did this was 2013, and now I'm planning to replace everything except maybe the power supply and case. I'll need some help, since I've been mostly out of the loop from the hardware community since my last upgrade.
FYI:
Country: I'll be flying to the US soon (staying in Detroit for a few weeks, then NY till September), so I'll buy the components there (online also a possibility if done early). Store recommendations will be appreciated!
What do I use my pc for?: Mostly audio/video editing and gaming (from League/WoW to GPU-intensive FPSs). I'm also very interested in VR, so it needs to be ready for that too.
Budget: Not really limited here, but I rather not spend a fortune, so no extreme versions or dual-gpu setups (unless it's REALLY worth it).
Overclocking: I used to be huge into OC'ing the hell out of everything, but now I aim for system stability/longevity and don't want any issues. Any OC'ing done will be very minor (a few MHz here and there), if at all.
Resolution: I'll be buying an Acer Predator X34, so that'd be 3440x1440.
Parts I plan to keep: Coolermaster Cosmos II case, Corsair Ax860 power supply.
Q's:
-Is my Corsair Ax860 compatible with a 2011v3 MB/Broadwell-E CPU? Unsure if connectors have changed. Btw, this ps is only 2 years old and functioning perfectly. I think 860w should be more than enough for a single GPU system, but I will upgrade if it's needed.
-I already have a Samsung 850PRO 512gb SSD that I bought last year (and a bunch of other SSDs/HDDs), but I've read that some PCIe SSD drives are relatively accessible and offer insane performance gains. Knowing what I already have, is it worth spending money there?
-I've been checking out newegg and there's a huge variety in motherboards. I usually go for the higher end ones even if I don't plan to OC (just because of the higher quality parts), but recommendations will surely make my life easier!
-CPU: 6800k, 6850k or 6900k?
-Ram: Again, huge variety. No idea what to pick (usually go for Corsair/GSkill). DDR4: Dual channel or quad channel?
-VGA: I'm pretty sure this one will be down to availability since the FE GTX1080 is proving to be a PITA to find and buy, but any recommendations or tips will help lots.
That's all for now. Thank you guys a lot
FYI:
Q's:
