Virtual machine software
Epyon
I have a spar Win 10 key and want to set up a VM inside my main Win 10 OS to do all of my internet browsing and downloading. and keep my main OS to just downloading updates. I have no idea what VM software to use on windows. Can any one make suggestions?
DogsofJune
Would Sandboxie be an easier solution?
"Sandboxie uses isolation technology to separate programs from your underlying operating system preventing unwanted changes from happening to your personal data, programs and applications that rest safely on your hard drive."
Grimham
Which version of Win10 do you have installed on your main rig? If you have Win10 Pro hyper-v is already built into the OS.
If you have Win10 Home I'd go with VirtualBox.
