Executioner
- Apr 22, 2015
I started with VB first with Win 7 installed. Seem to work fine, but after a few days, I began to have issues with copying files back and forth between OSes. I have the guest additions installed and it worked fine for the first few days. I also wanted to increase the size of the OS, but it seemed like a PITA to modify.
So I noticed the VMWare Player has a version for Linux, so I deleted the VB and installed VMWare Player. Easy to install, including asking me to install VMWare Tools. Seems to me that VMWare is more of a polished application. The only bummer with the free version is it does not create a snap shot like VB, but I could copy the files by zipping them.
Curious what you guys use in comparison.
