I'm having some trouble with virtual memory. Whenever I run Battlefield 2, Its choppy. VERY choppy. I narrowed it down to a memory problem, and figured maybe it was the virtual memory. So i disabled it and ran BF2, and with VM disabled it ran smooth as silk. Just as a confirmation that it was in fact VM, i re-enabled it and BF2 became choppy again. Now here is the issue - I don't have enough memory to run completely on physical. BF2 will eventually crash when i run out of memory (normally about halfway through a map or when a map is fully loaded and I'm about to play). So I must have Virtual memory.
So I was wondering if anyone knew how to force BF2 to stay in Physical memory while everything else goes to the swap space.
