RanceJustice
- Jun 9, 2003
edit: The forum Media capture for IndieGoGo doesn't seem to be working here.. here is the address with a space in it.
indiegogo DOT com/projects/vinpok-split-best-on-the-go-touch-screen-monitor/
What does everyone think of this? As far as portable monitors go, the IndieGoGo price of $199 seems to be pretty reasonable , considering it is IPS 15.6" 1080p, 10 point touch screen, has HDMI and USB 3.1 TypeC connections + audio out, and can be connected with a single Type-C cable etc. Its nice they add speakers, even if they're rather small, but the 3.5mm audio out seems to be another alternative. They show it clipped onto laptop or desktop monitors to quickly add another monitor, used stand alone for game consoles like PS4 / Nintendo Switch, and other tasks.
Edit: You can power it either with a single USB 3.1 Type C (ie any one with DisplayPort spec built in) which also serves as the display input or you can use a separate USB 3.0 port > TypeC as the power and then the other Mini-HDMI or USB-C for video.
The touchscreen is a nice function given that they claim the whole thing supports Win/Mac/Linux , so testing out a new system/config without having to set up KB/M could be nice. Accessories include a $9 clip for attaching it to a laptop/desktop display and a $20 kickstand - given how far this had been funded, I can hope that one or more of these will be included in the base price by now, but they should be updating stretch goals in the next day or two.
I do have a couple of questions regarding input lag and the compatibility of the capacitive touch screen I'll have to ask (ie will it be natively supported under all OSes they';ve noted including Linux).
I've been considering picking up a a secondary monitor for quite some time and I'm wondering if this is worth it or not. On one hand a stationary monitor will be larger, but it won't have the touch screen, and IPS / small bezels / USB-C / lack of power adapter necessity etc.. are less likely to be found or more likely to increase the price, I figure. At least as far as portable specific monitors are concerned (ie the one by Hori made primarily for console gaming), most of them seem to have lesser specs / features especially for the price (ie TN panels, no touchscreen, no USB-C / required DC power supplies etc), but maybe I've missed something.
So does everyone think this is worth looking into? If not ,is there something that fills its niche better for a portable high quality monitor or a better solution for a stationary secondary monitor instead with comparable or better specs (minus touchscreen etc)?
