cocheese256
- Apr 23, 2005
I am thinking about getting a Viliv S5. I like the compact design and the fact that it runs WinXP as the OS. One of the uses for this device will be in my truck to listen to music.
This poses a problem however. The screen is quite small, so using standard programs to play and control music could be quite difficult while driving. I would like a media program that would pretty much work like the GUI of a dedicated MP3 player. I would like the program to be able to set up playlists as well. Itunes would work if I only used the album art feature, but would be very difficult to use with the playlists. I have been experimenting with some Winamp skins on my desktop, but I am not sure if I have found any that would translate into a good touchscreen app. If anyone has any suggestions I would greatly appreciate it.
Thank you in advance.
