Hello,
I plan to buy a 24'' gaming screen, 144 Hz, 8bit color, pwm flicker free, low response time and input lag. And as good image quality and black levels as possible. I know this means TN panel, but I am fine with that for now.
Doing some research, I found these 3 monitors that qualify:
- ViewSonic VG2401MH
- LG 24GM77
- Eizo FG2421
Are there any more worth mentioning? The ViewSonic is the cheapest, and have had good reviews from what I can see. But it also seems to have the highest input lag. Eizo stands out with its black levels, I think, but possibly bad QC from what I have read. LG is more expensive than ViewSonic, and has the strobe thing that I probably don't prioritise.
Difficult choice. What is acceptable input lag today? I know that for fps games you probably want < 5ms, and I think the ViewSonic one has 10ms. Noticeable?
This will be my first gaming monitor for a long time, so I cannot relate much to response time, input lag, etc. But I want to make the best buy I can based on information. I plan to get something better in a year when we have more alternatives for g-sync, and free-sync.
You guys have any input on the above monitors?
- LG 24GM77
- Eizo FG2421
