VonGriffin
- Oct 15, 2013
Frankly, I don't give a shit whether it's "midrange" or not.
i do if it sells for 500 bucks,,,
GoldenTiger said:RUMOR:
Cards in reviewers' hands:
http://tieba.baidu.com/p/3287030270?pn=1
Forum translated says that he is working on his review now and it is a review sample... device ID begins with 13 from the new drivers for the 970 and lists 1664 cores. 13 SMM's * 128 cores per SMM = 1644, so it adds up.
The new device ID from public drivers matches as well for this 970. The 980 has ones beginning with 16 and 17 which would presumably mean 16 or 17 SMM's * 128 = 2176 or 2048 cores!? Wowza.
This matches the older leaks from coolaler.
Device ID NVIDIA_DEV.17C2 = "NVIDIA Graphics Device" is in drivers as well as one DEV.13C2 which matches this picture. This lends credence to a 17 SMM 980 part.
I'm referring to the relative value of the GTX 670 to the 680. The GTX 680 was 25% more expensive then the 670 ($500 vs $400) but the performance gap was much lower than that and actual technical gap (in terms of what was cut) was quite low relative to that price difference.
If you felt the 670 was a bad value then the 680 would be atrocious by comparison. And I guess correspondingly the then price of the 7970 would be indescribably bad? lol...
Of course 500 bucks is not midrange but you did not even understand anything I said. How many times does it have to be explained that the chip is midrange?
Really wish they would just release something concrete already to give you kids something better to talk about
Says one of the "kids" talking here.
Glad you felt singled out by my comment
Cute, but no, I was just laughing at it, not responding .
... If the aftermarket doesn't stick huge coolers on them like the 750 Ti.Nice to see some more short-PCB cards. Going to make ITX builds very, very happy
Well, in the case of the 750 Ti, that problem is easily rectified.... If the aftermarket doesn't stick huge coolers on them like the 750 Ti.
670/680I think that this is the first time where a GTXx70 middle high end series has the same ram as the corresponding high end series GTXx80
