Video card upgrade for older machine
compslckr
So I went to fire up the battlefield 1 beta today and discovered my current card is too old (driver outdated and no newer version available).
Ordered a PNY 1060 (https://smile.amazon.com/dp/B01IR5MR32) from Amazon, how bad of a bottleneck will the rest of my machine be with this card?
Current system (circa early 2011)
Sandybridge i5 2500k at 4ghz
MSI P67A-C43 motherboard (I think this only has PCI express 2 x16 slot, not 3)
8Gb ram
MSI HD 6970
256gb crucial m3
2tb wd black
Thermaltake TR2 TR-600
looking to game at 2560x1600, single monitor.
jspringer
will be a slight bottleneck but not to bad and with you running at 2560x1600 might not be a bottleneck at all.you would see more of a bottleneck running at lower res
primetime
you be fine.....that game pushes 6 threads well so dont plan on doing a lot of multi tasking;) could always spend a hundred and drop a Xeon E3-1230 in it
i7Baby
Your monitor is 1920 x 1200. A gtx 1060 (3 or 6gb) will be fine. Your i5 will run it fine as well.
compslckr
Monitor is 2560x1600, but I don't need to max everything out. Most of the gaming I do is still older games anyways.
compslckr
Turns out that the 1060 was a great choice. Picked up another 16gb of ram and have been getting 60fps on ultra @ 2560x1600. Some tearing and dips down to ~48fps during crazy explosions and stuff. Overall, totally stoked with the purchase.
Archaea
CPU is probably at 50%
Your CPU isn't the bottkeneck. Open up task manager or perfmon while playing the game. Graph CPU usage. Report back.
skeeder
8Gb ram
MSI HD 6970
256gb crucial m3
2tb wd black
I have a similar system. I just installed a new 1060 6g and have an i5 2300.
The machine just plows through bf4 with everything on ultra. (With bounce off I was averaging 100fps).
I did notice my cpu was maxed the whole time, so I might be bottlenecking somewhat, but at those frames, I'm not going to notice.
