the card itself of the metal bracket which connects in the back?
eh
it should fit
all of those metal brackets are standard for every case.
just fiddle around with it. also in some cases(mostly prebuilt) there is alittle aluminum annoying bracket thing on the slots. you can easily rip it out with pliers. it is extremely useless so try that and there you go.ill get a picture to show you.
