Vetroo V360 Black/White ARGB 360mm AIO Cooler - $50
Status
Not open for further replies.
T4rd
Damn, bout to impulse buy it right now, but can't find the compatibility with my old HAF X case to see if it'll fit the 360mm rad. I'm assuming so since cases don't get much larger than it.
Corporate Thug
stupid question: what is the shelf life of these things? Thinking about buying it as a back up cooler. Any issues with the water over an extended period of time?
JasonPC
TBH the biggest problem is most likely the pump going out on you before the cooling fluid dries up.
I’ve had a few asetek based aio’s and only the one I had problems with was the evga liquid cooling kit for the gtx 980. The pump stopped working and the card would overheat and throttle.
Status
