oOo sam lee oOo
- Aug 29, 2004
you know when you reformat, bootup should take like 15 or 20 seconds from the windows xp logo screen to the desktop? well, my computer used to do that, and it'd bootup in like 3 sweeps of the little blue bar, and then spend about 5 seconds on the welcome screen, and i was on the desktop. (i guess less than 15 seconds) but now, when i reformat, it takes forever, it takes at least 12 or 13 sweeps or the blue bar, and spends probably 30-40 seconds on the welcome screen before it gets to the desktop all loaded up. i ran memtest about two weeks ago overnight, and there were no errors. i dunno how ot check everything else though. could it possibly be becuase i've reformatted so many times? doesnt seem likely, but maybe? or maybe something wrong with cpu?
winxp w/sp2
2.8ghz p4@~2.98
512mb pc3200 ram (kingston, corsair? one of the two)
2x120gb wd IDE hd's, one curently disconnected in case it had something to do with it (#2 has all my music and vids)
i also tried lessening what goes on during startup, but it doesnt seem to make a difference. i didnt even have to do this before.
btw: once its all loaded up everything works fien excpet for some lag here and there
thanks
winxp w/sp2
2.8ghz p4@~2.98
thanks
