veristor question
the snake
i am trying to attempt to fix a makita battery charger that smoked a varistor and the soldered in fuse, i have the parts but was wondering if the varistor needs to go a certain way ?
like is there postive or negative ?
would that be considered polarity ?
i can't find a schematic but ordered the parts from a online tool parts house
Mohonri
Can you post the part number? With that, we can figure out which way is right.
Seithennin
Varistors (Voltage Dependant Resistors) have no polarity.
the snake
i have no idea what the part numbers are as i cant find any schematics from makita, but bought parts online from a tool repair site that worked.
i kinda guessed that and took a chance, 50/50 odds and it worked :)
