Hey guys, ok i put together a comp last month and just jumped on the cheapest RAM option i could find (Patriot Sector 5 1333 CL9) well they wont even do 1333 @ 1.65v so im stuck at 1066 @1.5v right now...
Needless to say im RMAing them, but now ive done a little more research into options and am wondering what people would recommend? Let keep it to reasonably priced kits, as its been shown SB isnt that picky
What are you guys using and have you been able to overclock it at all? Any new stuff just out?
I like the Snipers, for the lowprofile, are they the same IC's as the ripjaws? or possibly Vengeance's? but i hear the heat spreader issues, lowprofile ones? and i also saw some XMS3's that are supposedly now 1.5v...so many choices, im only one man...
Thanks
Thanks
