After reading the HardOCP comparison between Vega and Fury X at the same clocks, thought this one was interesting too. The conclusion seems to be that there is literally no difference in performance between Vega 56 and 64 when they are at the same clocks, regardless of the fact that the 56 is a cut down chip. It makes even more sense now why AMD chose to handicap the 56 with lower memory clocks. This is the first time where it almost seems like selling the chips based on shader counts makes less sense than just binning them and selling them based on clockspeed if the shader counts are having no effect on performance. The other thing I'm seeing posted a lot is the idea that Vega is so bandwidth starved that you would only see the 64 pull away at extremely high memory clocks. Thoughts?
