VDROP - issue? Whea-logger 19 events each second on event log on idle only.
Discussion in 'Intel MoBos' started by mgty23, Nov 9, 2018.
  1. mgty23
    mgty23 Limp Gawd
    146
    Mar 16, 2017
    Uh hello again. Its my next topic in short time heh.
    Windows 10 1803 actually.
    A spam of:
    WHEA Event ID 19 CPU-corrected hw error
    A corrected hardware error has occurred.
    Reported by component: Processor Core
    Error Source: Corrected Machine Check
    Error Type: Cache Hierarchy Error
    Happens only on idle. Clocks are jumping and voltages are jumping too on idle, but its normal i think.
    SO maybe VDROOP? But if VDROOP why it wasnt happening when i was plugged with 1080 ti aorus. Heh?
    During games,benchmrks no whea loggers.
    Yeah i know its january ( it happened in january too but it stopped until i plugged in october 2080 ti )
    My pc:
    8700K ( MCE is on )
    2x8GB DDR4 3000MHZ GSKILL
    Corsair 750rmi
    Asus Z370 Pro Gaming ( bios old from august 2017 )
    Gtx 2080 Ti Gigabyte Windforce ( actually ). On january i had Aorus 1080 ti.
    1xssd , 1xHdd
    Conclusion: It happened again repeatedly after plugging Gigabyte Windforce 2080 ti . That whea-logger 19 cache hierarchy error ( warning ). Windows 1803 the newest build ( KB ) installed in 05 may.
    Each warning 1 minute only on desktop/idle. When gaming or full load , not warnings.
    Also pc stable,no errors,crashing. Any ideas?
  2. pendragon1
    pendragon1 [H]ardForum Junkie
    10,671
    Oct 7, 2000
    update your bios and try another psu. seen several people with psu issues and 2080ti.
  3. mgty23
    mgty23 Limp Gawd
    146
    Mar 16, 2017
    nah psu i think !!!!!!! on full load its fine no warnings no crashes,restart freezes heh. On idle fine too just that stupid warnings :) But thx for suggestion also change psu for this? nah ! :D hehe
  4. mgty23
    mgty23 Limp Gawd
    146
    Mar 16, 2017
    hey little update. I change power plan to high performance ( 4700mhz clock on idle and voltage 1.4 core voltage according to cpuz ) and the same whea logger 19 every minute on log. So then i change to power saver to lock on 800mhz - 1200mhz with low voltage and the same logs. Only on idle it happens.
    During games or cinebench no wheas ( even with 4700mhz and voltage ). So i am lost now. So if this is not voltage so what?
  5. Denpepe
    Denpepe Gawd
    874
    Oct 26, 2015
  6. Meeho
    Meeho [H]ardness Supreme
    4,194
    Aug 16, 2010
    Do you have negative vcore offset set in BIOS?
