Im having a problem overclocking my rig as far as Id like to.
I have a Phenom 9850 BE running in an MSN M2N-E (I know, its not a native AM2+ motherboard) The problem I am having is with my Vcore and getting an accurate indication for what it really is.
Right now my CPU is running @ 2.7Ghz (200 x 13.5), the Vcore in the BIOS is set to 1.400V, and I have the CPU Vcore Offset Voltage in the BIOS turned on which is giving me an extra 50mV.
My problem is that according to the hardware monitor in my BIOS my actual Vcore is 1.43V. According to CPU-Z and OCCT, however, my Vcore is 1.28V at idle and drops down to 1.216V when all four CPU cores are under full load.
My issue is that the CPU is not stable above 2.7 and Im hesitant to turn the Vcore up much higher without knowing what its *actually* running at.
At this point I have two questions. Is there a way to tell if the hardware monitor in the BIOS is right or if CPU-Z is right? Also, is it normal to see a 0.2V difference between what I set in the BIOS and what CPU-Z actually shows, and if not is there a way to fix it.
If it helps to know, check my sig for complete system specs.
