CaseyBlackburn
- Dec 10, 2006
I am having an issue with my program in VB.Net. I am wanting a way to show a Balloon off the NotifyIcon that shows information and allows events. My code works in XP, but not in Vista. I assume since the code uses the Windows API. Can anyone help?
Balloon Class:
It get's called in a matter like this:
Balloon Class:
Code:
Imports System.Runtime.InteropServices
Class Balloon 'begin balloon class
Private Const WM_USER As Long = &H400
Private Const NIF_MESSAGE As Int32 = &H1
Private Const NIF_ICON As Int32 = &H2
Private Const NIF_STATE As Int32 = &H8
Private Const NIF_INFO As Int32 = &H10
Private Const NIF_TIP As Int32 = &H4
Private Const NIM_ADD As Int32 = &H0
Private Const NIM_MODIFY As Int32 = &H1
Private Const NIM_DELETE As Int32 = &H2
Private Const NIM_SETVERSION As Int32 = &H4
Private Const NOTIFYICON_VERSION As Int32 = &H5
Private Const NIIF_ERROR As Int32 = &H3
Private Const NIIF_INFO As Int32 = &H1
Private Const NIIF_NONE As Int32 = &H0
Private Const NIM_SETFOCUS As Int32 = &H3
Private Const NIN_BALLOONSHOW As Long = (WM_USER + 2)
Private Const NIN_BALLOONHIDE As Long = (WM_USER + 3)
Private Const NIN_BALLOONTIMEOUT As Long = (WM_USER + 4)
Private Const NIN_BALLOONUSERCLICK As Long = (WM_USER + 5)
Public Enum BalloonMessageTypes
None = &H0
Info = &H1
[Error] = &H3
End Enum
<StructLayout(LayoutKind.Sequential)> _
Private Structure NOTIFYICONDATA
Public cbSize As Int32
Public hwnd As IntPtr
Public uID As Int32
Public uFlags As Int32
Public uCallbackMessage As IntPtr
Public hIcon As IntPtr
<MarshalAs(UnmanagedType.ByValTStr, SizeConst:=128)> _
Public szTip As String
Public dwState As Int32
Public dwStateMask As Int32
<MarshalAs(UnmanagedType.ByValTStr, SizeConst:=256)> _
Public szInfo As String
Public uTimeout As Int32
<MarshalAs(UnmanagedType.ByValTStr, SizeConst:=64)> _
Public szInfoTitle As String
Public dwInfoFlags As Int32
End Structure
Private Declare Auto Function Shell_NotifyIconA Lib "shell32" (ByVal dwMessage As Integer, _
ByRef pnid As NOTIFYICONDATA) As Integer
Public Shared Sub DisplayBalloon(ByRef NotifyIcon As System.Windows.Forms.NotifyIcon, ByVal BalloonTitle As String, ByVal BalloonText As String, _
Optional ByVal MessageType As BalloonMessageTypes = BalloonMessageTypes.None)
Dim typNotifyIcon As Type = GetType(System.Windows.Forms.NotifyIcon)
Dim ptrWindow As IntPtr = (CType(typNotifyIcon.GetField("window", System.Reflection.BindingFlags.Instance Or _
System.Reflection.BindingFlags.NonPublic).GetValue(NotifyIcon), System.Windows.Forms.NativeWindow)).Handle
Dim id As Int32 = CType(typNotifyIcon.GetField("id", System.Reflection.BindingFlags.Instance Or _
System.Reflection.BindingFlags.NonPublic).GetValue(NotifyIcon), Integer)
Dim clsNID As NOTIFYICONDATA
With clsNID
.szTip = ""
.dwState = 0
.dwStateMask = 0
.hIcon = IntPtr.Zero
.uCallbackMessage = New IntPtr(&H200)
.uID = id
.hwnd = ptrWindow
.szInfo = BalloonText
.szInfoTitle = BalloonTitle
.uFlags = NIF_INFO
.cbSize = Marshal.SizeOf(clsNID)
.dwInfoFlags = CType(MessageType, Int32)
.uTimeout = NOTIFYICON_VERSION
End With
Dim result As Int32 = Shell_NotifyIconA(NIM_MODIFY, clsNID)
End Sub
Public Shared Sub HideBalloon(ByRef NotifyIcon As System.Windows.Forms.NotifyIcon)
With clsNID
.szTip = ""
.dwState = 0
.dwStateMask = 0
.uID = id
.hwnd = ptrWindow
.szInfo = ""
.szInfoTitle = ""
.uFlags = NIF_INFO
.dwInfoFlags = CType(BalloonMessageTypes.None, Int32)
End With
End Sub
Public Shared Function HookBalloonEvents(ByVal NotifyIcon As System.Windows.Forms.NotifyIcon) As NotifyIconBalloon
Dim clsEvents As New NotifyIconBalloon
Dim ptrWindow As IntPtr = (CType(typNotifyIcon.GetField("window", System.Reflection.BindingFlags.Instance _
Or System.Reflection.BindingFlags.NonPublic).GetValue(NotifyIcon), System.Windows.Forms.NativeWindow)).Handle
clsEvents.AssignHandle(ptrWindow)
Return clsEvents
End Function
Public Class NotifyIconBalloon
Inherits System.Windows.Forms.NativeWindow
Public Event BallonHidden()
Public Event BallonShown()
Public Event BallonTimedOut()
Public Event BallonClicked()
Friend Sub New()
End Sub
Protected Overrides Sub WndProc(ByRef m As System.Windows.Forms.Message)
Select Case m.LParam.ToInt32
Case NIN_BALLOONHIDE
RaiseEvent BallonHidden()
Case NIN_BALLOONSHOW
RaiseEvent BallonShown()
Case NIN_BALLOONTIMEOUT
RaiseEvent BallonTimedOut()
Case NIN_BALLOONUSERCLICK
RaiseEvent BallonClicked()
Case Else
End Select
MyBase.WndProc(m)
End Sub
End Class
End Class 'end balloon class
Code:
Private m_clsBalloon As Balloon.NotifyIconBalloon
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
'if we haven't already, hook into the NotifyIcon to trap balloon interaction events...
If m_clsBalloon Is Nothing Then
m_clsBalloon = Balloon.HookBalloonEvents(NotifyIcon1)
AddHandler m_clsBalloon.BallonClicked, AddressOf BalloonClicked
AddHandler m_clsBalloon.BallonShown, AddressOf BalloonShown
AddHandler m_clsBalloon.BallonHidden, AddressOf BalloonHidden
End If
'show the balloon...
Balloon.DisplayBalloon(NotifyIcon1, "This is a test", "This is a test balloon. Click on it to raise a click event...", Balloon.BalloonMessageTypes.Info)
End Sub
Private Sub BalloonHidden()
MessageBox.Show("Balloon Hidden!")
End Sub
Private Sub BalloonShown()
MessageBox.Show("Balloon Shown!")
End Sub
Private Sub BalloonClicked()
MessageBox.Show("Balloon Clicked!")
End Sub
