Vandal Switches and the Lian Li PC-7/PC-60
EPS Sniper
Quick question for you guys: I want to buy a Bulgin Vandal Switch for the power button on my Lian Li PC-7 Plus II but I want to know if any modifications are required to fit it in physically. I know that it'll fit the hole in the bezel just fine, but depth-wise will it clear without any modifications to the frame of the case itself? I've been searching and most people have this in different Lian Li models, so I wanted to see if this would fit. Thanks! :)
Nighted
Nope, you have to drill into the chassis. Look around the forum, you'll see it done a few times.
EPS Sniper
Ah, I see. I'll probably tackle it and a few other things when I decide to powdercoat the chassis. Thanks for the answer :)
