Valley Benchmark and my score
Xa3phod
Trying to stretch my rig as far as it will go. I ran the Valley benchmark, how does it look? Time to upgrade or am I doing well enough?
I understand the Sandy Bridge is a bit old, but I have it OC'ed to 4.4Ghz on Air. Will upgrading see any upgrade in performance?
How does your rig perform on Valley Benchmarks?
Unigine Valley Benchmark 1.0
FPS:
53.7
Score:
2246
Min FPS:
26.6
Max FPS:
98.4
System
Platform:
Windows 8 (build 9200) 64bit
CPU model:
Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz (3399MHz) x4
GPU model:
NVIDIA GeForce GTX 970 10.18.13.5891 (4095MB) x1
Settings
Render:
Direct3D11
Mode:
1920x1200 8xAA fullscreen
Preset
Custom
Quality
Ultra
FPS:
53.7
Score:
2246
Min FPS:
26.6
Max FPS:
98.4
For a comparison...
My 3770 w/ tiny o/c to 4.0 GHz w/original Titan (runs stock @ 1045 MHz), rest of my rig in sig, running the same setup as you, D3D11, 1920x1200, 8xAA, full-screen, Sound on, Win7 x64 (only difference) with everything maxed:
FPS:
52.2
Score:
2184
Min FPS:
26.1
Max FPS:
96.7
Valley hardly uses any CPU at all, it's just a stationary benchmark (more focused on GPU stressing than CPU).
If you want to test if you're CPU-limited or not, you'll need to run FRAPS with your game of choice.
If it's single-player (repeatable), Just record your framerate at your monitor's native resolution. Then lower your resolution, and see if your framerate goes up.
If it does not go up, you're CPU-limited.
FPS - 94.8
Score - 3967
min - 28.2
max - 184.4
Evga 980 ti classified, 4790k at 4.6GHz.
I can tell you that clocking up my cpu barely makes any impact on this benchmark or the Heaven one. My cpu can more or less do 4.8GHz but the voltage required (and in turn, heat generated) just isn't worth it unless you're in a 3dmark or specific benchmark competition. If you want to see that benchmark increase a great deal - clock the video card up or upgrade it.
Just picked up my brand new system this morning
FPS:
58.9
Score:
2465
Min FPS:
31.2
Max FPS:
109.0
System
Platform:
CPU model:
Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz (4007MHz) x4
GPU model:
NVIDIA GeForce GTX 980 Ti 10.18.13.6143 (4095MB) x1
Settings
Render:
Direct3D11
Mode:
2560x1440 8xAA fullscreen
Preset
Custom
Quality
Ultra
FPS:
58.9
Score:
2465
Min FPS:
31.2
Max FPS:
109.0
System
Platform:
CPU model:
GPU model:
Settings
Render:
Direct3D11
Mode:
Preset
Custom
Quality
Ultra
You score 600 more points than me on my FURY + x99 system?????..waaaaa
FPS:
46.6
Score:
1950
Min FPS:
23.9
Max FPS:
88.8
System
Platform:
CPU model:
Intel(R) Core(TM) i7-5820K CPU @ 4.20GHz (4200MHz) x6
GPU model:
AMD Radeon (TM) R9 Fury Series 15.200.1062.1004 (4095MB) x1
Settings
Render:
Direct3D11
Mode:
Preset
Custom
Quality
Ultra
I get 1871 with my R9 Nano, 1687 with my NITRO 8GB, and 1494 with a Geforce 970
My old system still doesn't do too bad.
FPS:
83.1
Score:
3478
Min FPS:
30.0
Max FPS:
145.3
System
Platform:
CPU model:
Intel(R) Xeon(R) CPU X5670 @ 2.93GHz (3648MHz) x6
GPU model:
NVIDIA GeForce GTX 680 10.18.13.5891 (2048MB) x2
FPS:
46.6
Score:
1950
Min FPS:
23.9
Max FPS:
88.8
System
Platform:
CPU model:
GPU model:
Settings
Render:
Direct3D11
Mode:
Preset
Custom
Quality
Ultra
I put a slight overclock on my card and increased it to:
66.3 FPS
Score 2774
Min FPS 34.8
Max FPS 124.5
Still same settings and resolution :cool:
66.3 FPS
Score 2774
Min FPS 34.8
Max FPS 124*.5
At that resolution I got
63.5
2655
35.1
117.5
You guys should run it at the OP's settings, 1920*1200 for a fair comparison to him.
63.5
2655
35.1
117.5
I lowered my resolution to 1920x1200 for apples to apples and got:
FPS 88.3
Score 3696
Min 37.2
Max 166.4
