Pyroja
- Jan 4, 2005
Short version: I have a 60hz monitor plugged in, but for some reason V-Syncs keeps the framerate at 120fps, causing minor tearing.
Longer version: My primary display is 60hz. For kicks and giggles, I hooked up a 120hz projector and gamed on it for a bit. Disconnected it and went back to my 60hz monitor. Ever since then, all my games stick to 120fps with V-Sync on, despite my monitor being 60hz (and being set to 60hz in display properties). It's annoying because I'm getting some minor screen tearing and I really want this fixed.
I've already completely uninstalled the AMD drivers and CCC and reinstalled. That didn't help. I tried gaming on my second monitor via the IGP and V-sync works properly there, so this has to be some sort of driver issue... Or so I would think.
Any help would be much appreciated.
EDIT: Disabling CrossFire gets V-Sync working properly. Re-enabling it makes the problem return. Odd, since I've been running this Crossfire setup for years and have never, ever had this problem until now.
