[V]ery Warm- SanDisk Ultra 32gb USB 3.0 $12, 128gb USB2.0 $30. TODAY ONLY
NeonFlak
I'll just throw out there that the USB 3.0 version has some major difference in speeds. Unless something has changed, we had a bunch of these for work a couple months ago and no two had the same results. And none of them reached advertised speeds.
Trimlock
I have the 64gb stick and it barely made USB 2.0 speeds. Not that I'm complaining though, I bought it for the storage and not the "speed."
nilepez
If you need a small drive, the 32GB might be OK, but at this point, a good USB 3.0 is what I'd get...especially for the 128 GB drives, because when I use those, I'm dumping a ton of data on them and 3.0 speeds are already slow enough..especially if i encrypt the files. 2.0 is only good if I"m doing it before bed.
T4rd
Wow, nice. My old 8GB just died. 32GB is way more than I need for school, so I'll pick this up. Thanks, OP!
