http://www.utorrent.com/
HUGE changelog, but well worth it.
http://www.utorrent.com/download/1.5/utorrent-1.5.txtChangelog said:--- 2006-03-07: Version 1.5 (build 436)
- Feature: Setting to determine the number of µTorrent users.
- Feature: Use icons instead of network ok/nat error
- Feature: Auto detect read cache size
- Feature: Language file can be auto updated
- Feature: Keys can be used in main listview to move to the right item
- Feature: New easter egg
- Feature: RSS Help button
- Feature: Reorder RSS favorites
- Feature: If user is running from temporary internet files, prompt to install it.
- Feature: Added popup menu to easily change if the scheduler/dht is enabled.
- Feature: Added log-to-file option in logger.
- Feature: Option to always prioritize the rarest pieces.
- Feature: Added active/inactive categories in category list
- Feature: DEL key works in RSS history, and the last item is selected
- Feature: RSS history remembers only 500-600 items
- Feature: XML parser supports # tags
- Feature: Determine the values to show in the speed popup list automatically.
- Feature: Category list to filter main torrent list.
- Feature: Propagate encryption support through PEX
- Feature: Choose what happens on double click in torrent list
- Feature: Show a special message if utorrent crashes while NOD32 is active.
- Feature: Added scheduler mode to seed only (hold Shift button)
- Feature: Support min_interval key
- Feature: Ctrl Up/Down to move up/down a torrent
- Feature: Show average up/down speed since start.
- Feature: Show encryption status in Flags field
- Feature: Copy hosts from peer list
- Feature: Peer Exchange (only with µT peers for now)
- Feature: Protocol Encryption (compatible with future azureus)
- Feature: Bypass Windows XP Firewall
- Feature: Make torrent prioritized from add torrent window
- Feature: RSS toolbar button
- Feature: Smart RSS episode filtering - avoids downloading the same ep twice.
- Feature: ESC minimizes
- Change: Rearranged settings dialog
- Change: Default to priorizing rarest pieces
- Change: Switch default theme
- Change: Skip hidden/system files when creating torrent.
- Change: Right align some columns.
- Change: Remove spaces from urls in RSS feeds
- Change: DHT binds UDP socket to net.bind_ip
- Change: Smarter block hashing, tries to avoid re-reading from the file if possible.
- Change: Tracker connections obey max_halfopen/max_connections
- Change: Switching folder in the Add window tries to detect if you point at an already downloaded folder.
- Change: Added support for " in XML parser
- Change: Optimized disk-io
- Change: coalesce_writes defaults to true
- Change: &Exit to E&xit
- Change: Show up/down arrows in listview headers
- Change: Rearranged some stuff in the settings dialog
- Change: Add FAQ to the help menu
- Change: Use UTF-8 instead of utf-8 in created torrents.
- Change: Min autodetected piecesize is now 64k.
- Change: Remember last active RSS page.
- Change: Don't increase counters while paused.
- Change: Auto detect if RSS feed uses latin1 or utf8.
- Change: Sort by scrape peers instead of connected peers
- Change: Relevance rounds up instead of down.
- Change: Rename langpack to utorrent.lng.
- Change: If langpack is in the exedir, it gets installed to APPDATA.
- Change: Remember if torrents have errored when you restart
- Change: Optimizations to piecepicker algorithm
- Change: Fast/Slow pieces
- Change: Simplified encryption settings
- Change: Support langpack.zip with translations.
- Change: Don't download first/last piece of a file first. Can be re-enabled.
- Change: Added a black down image to the spyglass icon
- Change: Protect webui with a password
- Change: Include beta build # in http requests.
- Change: Show <Search Here> in the search box.
- Change: Open partfile in read only mode if read/write fails.
- Change: Read cache uses less CPU
- Change: Support paths >260 chars.
- Change: Icons in RSS Releases (thanks TVTAD)
- Change: RSS Not filtering matches full release name
- Change: RSS Reader supports more date formats
- Change: Adjusted some lazy bitfield parameters
- Change: Renamed to RSS Downloader
- Change: Allow deleting multiple history lines at the same time
- Change: Improvements to RSS parser
- Change: Pause button toggles
- Change: net.low_cpu defaults to false.
- Change: Reworked network code for faster speeds.
- Change: Add torrent dialog defaults to whatever folder entered in settings
- Change: Added some qualities to rss reader
- Change: Changed date format
- Fix: Work better when large fonts are used.
- Fix: Prevent windows from going above pixel 0.
- Fix: Ratio on generals tab wasn't computed exactly like the main list.
- Fix: Crash bug with columns
- Fix: Better support for adjusted computer clock.
- Fix: Don't behave incorrectly if 0-byte files are deleted by the user.
- Fix: If the torrent storage path hasn't been created, create it.
- Fix: Fix a crash related to language packs.
- Fix: Superseeding works better
- Fix: RSS feeds are utf8-decoded
- Fix: Deleting from RSS history forgot about sorting
- Fix: Disallow some more characters from filenames
- Fix: Crash when deleting multiple items from RSS history
- Fix: RSS parser parsed month bad for some timestamps.
- Fix: Fixed crash in torrent creator
- Fix: Ipfilter memory leak
- Fix: Support mixes of name and name.utf8
- Fix: Sorting reverse by name didn't work
- Fix: Improved autoload so it waits a bit if the file hasn't fully been written to disk yet.
- Fix: Stop ALL torrents when scheduler is active.
- Fix: When moving a complete download, use the name entered in the add dialog instead
