I work at a phone company and am trying to figure out if I am getting the speed I configure ports on a Calix C7. I have a modem connected to a port that is trained up to 19000 Kbps. I have a ftp server set up on a laptop that is connected to our ISP's router. I can get an average of 32 Mbps down and 61 Mbps up. My goal is to verify that I am getting 19 Mbps on the DSL connection. When I do a speed test to our ISP I only get about 10 Mbps on the DSL port. I am trying to figure out if there is a problem in our C7 or if the ISP's speed test is wonky. When I download a file from the FTP server it says my transfer rate is 2776 KB/s. So I assume it means kilo bytes per second. That should be 2.7 mega bytes per second correct? I multiply that by 8 to get the mega bits per second? So that is 21 mega bits /second? Am I doing the math correctly? I suspect that I am not because when I transfer the same file to my office PC it transfers at 1600 kilo bytes /second. By my maybe flawed calculation it comes out to 12.8 mega bits /second. Which can't be correct because we only have a 7 Mbps connection in the office. Can someone straighten me out!
