Cerulean
- Jul 27, 2006
User opens a document \\region-fs1.company.local\share\Public\Engineering\Part-8513\document.doc, makes some modifications, saves and completely closes the file.
User attempts to cut and paste folder Part-8513 to a folder on Desktop but receives a message saying the the folder or files are in use/currently open/locked, offering the options Try Again or Cancel.
I login to region-fs1.company.local Windows 2012 file server, go to Computer Management, and check Open Sessions under Shares filtering for the full path. I discover that there are ZERO open files or sessions to either the parent folder Part-8513 or files contained inside this directory.
User is able to move/rename/delete all files inside parent folder, but not the parent folder itself (which triggers that in use message with the Try Again and Cancel buttons to pop-up).
User tells me that this only happens when they open a document that they are unable to move or rename the parent folder after closing the document, and that this doesn't "reset" until a day later. If they don't open any document, they can freely move folders around. User has many folders he needs to open and verify documents before moving or renaming the parent folder.
Ideas? User is using a Windows 7 Professional workstation. File server runs Windows Server 2012 Standard.
