[???] use USB C monitor without USB C?
Guys, a while ago the first true solution has come out - but I have been too busy and forgot to report it.
https://buywacom.com.au/wacom-link.html
Combines DisplayPort and USB into USB-C with alt-mode (to use the Wacom MobileStudio Pro as a monitor / drawing tablet for a computer).
This video seems to demonstrate it:
By the way, I believe that every laptop and smartphone with USB-C should be able to accept DisplayPort input to the internal display (either internal display needs to have multiple inputs, or the two will be switched to one input with a mux).
The only thing that is unclear is power delivery. The Asus Zenscreen only powers from the same USB-C port as the video, and this adapter may or may not deliver any power from the USB-A port to the USB-C port.
Assuming that the Zenscreen only needs bus power (5V@3A) which is highly likely, as extremely few laptops (and even desktops) have higher power delivery than this, you could take a USB-C to USB-C cable and shave the outer plastic off the cable, carefully retrieve the voltage lines and wire in another power source.
But the danger of this is if the cable is connected to two PD devices which negotiate higher voltage, which would then fry the device you spliced in. You would have to sever the CC lines for this, which might then affect orientation detection.
The only proper way to do it would be with a proper device with the mux to deal with plug orientation, and act as a PD source itself. But that is well out of reach of most individuals. I know there are people who are capable, like the person who sells the USB PD Sink Buddy https://hackaday.io/project/20424-pd-buddy-sink so perhaps send him a message and tell him you would pay if he made a device.
A device with 4x USB-C female ports, which passes data and alternate modes between two of the ports, but provides PD to each separately through their corresponding PD USB-C port (so each can receive 100W if you have two 100W USB-C chargers).
Which by the way, the Wacom MobileStudio Pro 100W USB-C charger is the first and only true 100W USB-C charger that I know of, that serves no function other than as an AC adapter.
https://buywacom.com.au/products/accessories/cables-and-power/power-adapter-for-mobilestudio-pro.html
Cheers for discussing this stuff, it is so good. And I wish there were more good forum topics about this.
joevt
[H]Lite
You have been too busy to read this thread which is only 4 pages long. The Wacom Link was discussed on page 3. It only works with the Wacom MobileStudio Pro. It doesn't work with other USB-C devices.
I don't think there's any USB-C device that has a USB-C port that can be used for both input and output. This might be possible with Thunderbolt 3 USB-C ports but only if the computer has firmware to enable it (which doesn't exist - Apple did it with some of their Thunderbolt 2 iMacs; actually, Apple did it with some of their DisplayPort only iMacs too).
I agree. More info: The Asus Zenscreen only requires about 8W according to their specs but that's more than a USB 3.0 type-A port usually puts out (900mA 5V 4.5W). Most (all?) computers won't supply power greater than the minimum required for the port type (no Battery Charging (BC) or Power Delivery (PD) from the computer, only to the computer). The Wacom MobileStudio Pro is powered by it's battery.
so perhaps send him a message and tell him you would pay if he made a device. A device with 4x USB-C female ports, which passes data and alternate modes between two of the ports, but provides PD to each separately through their corresponding PD USB-C port (so each can receive 100W if you have two 100W USB-C chargers).
That would be cool. He could base the design on the Cypress CCG4 Evaluation Kit (discussed on page 3; the Sunix UPD2018 also uses the CCG4).
Very nice. I have't seen anything more powerful than 85W before, but their specs say it's only compatible with the Wacom MobileStudio Pro. People have tried it successfully with a Surface Pro so I guess the Wacom power adapter is not as useless as the Wacom Link. There's a list of certified power bricks at http://www.usb.org/kcompliance/view/CertifiedUSBPowerBricks.pdf, but the max are 80W, 85W, 90W.
Sorry, my bad. Although I didn't think most people would read whole threads - often they are disjointed and have no continuity.
Halfdan
I read this whole thread and am not sure if I understood everything correctly. I want to connect an LG ultrafine 5K display to my ITX PC (Sandy bridge). As I understand I will need the following main parts (excluding additional necessary cables):
1. "IT-GO" PCI-e x16 Riser (QTY: 1) (or an equivalent 2x PCIEx 16 riser card)
2. Gigabyte GC-Alpine Ridge (QTY: 1)
Below is an image of how the above parts will have to be connected:
https://imgur.com/a/ag3bDHF
The red part I'm not sure about if it is necessary, since DM7 didn't use this for 2x 4K connection but someone else did say (joevt ?) that the Gigabyte card won't be recognized if the USB to PCIEx1 card isn't inserted into a PCIE port at power up when using thunderbolt port. Also I assume some things won't work well (brightness control?) with this setup as I'm leaving out the thunderbolt header connection?
joevt
[H]Lite
The USB connection was necessary with the GC-ALPINE RIDGE with a single slot PCIe riser that I tried (to start DisplayPort to Thunderbolt/USB-C conversion). A USB connection will not enable other functionality of the card (hot swap, PCIe tunneling, USB controller) because we don't have the software to enable those functions (or they can't be enabled).
A person has reported that a different Thunderbolt 3 add-in card did work with a single slot PCIe riser without the USB connection.
Two DisplayPort connections are required to get 5K on the LG 5K display. The GC-ALPINE RIDGE comes with two short DisplayPort to mini DisplayPort cables. You may want to buy two longer cables.
Without PCIe tunneling, you can't use functions of the LG display that require that (audio, camera, USB ports, brightness control).
You may be able to use a app that can send DDC/CI commands over DisplayPort to control brightness. Someone reported that this works, but the DDC/CI of the LG display is kind of broken (doesn't report current brightness value correctly).
https://apple.stackexchange.com/questions/61045/does-apple-support-ddc-ci-for-3rd-party-displays-via-apples-thunderbolt-to-dvi
https://www.tonymacx86.com/threads/gc-alpine-ridge-in-hands.206821/page-26#post-1790605
jamislike
I finally found a solution to get both DisplayPort and USB working, was quite expensive though.
I went ahead and bought the CY4541 EZ-PD CCG4 Evaluation Kit and it works perfectly. Cost me around the £230 mark, but it does have 2 usb-c sockets so you can drive two of them as i intend to do, you have to build your own enclosure to put it in however. But i can now connect displayport and usb to any machine and use the UltraFine 4K with all it's features. Here is a video :-
joevt
[H]Lite
"Found" is not exactly the right word, since the CCG4 Evaluation Kit solution has been discussed a few times in this thread. Maybe "tried" is a better word, unless you mean that you found a seller of the evaluation kit. Anyway, I'm glad someone tried it successfully. It seems much larger than it needs to be. I suppose that's because it does a lot more than we need it to do.
There might be another solution. The GC-TITAN RIDGE. It is similar to the GC-ALPINE RIDGE except for the following:
1) It supports DisplayPort 1.4 instead of just DisplayPort 1.2. The LG Ultrafine 4K only needs DisplayPort 1.2 max.
2) It supports power delivery up to 100W (optional, requires two 6-pin power supply connections). I don't know what would require more than the usual amount of power except maybe the ability to charge a laptop?
3) USB 2.0 comes from an external controller. This is strange since the GC-ALPINE RIDGE used the Thunderbolt chip for both USB 2.0 and 3.1 gen 2.
It is feature #3 that might allow getting both DisplayPort and USB to the LG UltraFine 4K display. USB will continue to be unusable for USB-C displays or docks that use two lanes of DisplayPort with USB 3.x. I haven't tried this configuration. It will work only if the GC-TITAN RIDGE allows the USB 2.0 passthrough without a PCIe connection to the computer (for the USB 3.x controller to function).
I've done some testing of the GC-TITAN RIDGE in a Mac Pro 2008 and also in a Sonnet Echo Express III-D connected to a MacBook Pro 2015. USB 3.1 gen 2 and USB 2.0 worked in both setups.
CoreStoffer
I finally just gave up: Sold the LG Ultrafine 5K and bought a BenQ SW271 instead. The LG 5K obviously worked great with my MacBook Pro 2016, but I have to hook the monitor up to a windows build soonish. Also, the BenQ SW271 is probably a better fit for my work after all.
joevt
[H]Lite
This appears to be your first post in this thread - It might be helpful to describe your attempt even if it was a failure and you don't want to try again. What computer and method of connection did you try? Why would you go from 5K down to 4K? The only problem with the LG 5K is the Thunderbolt input requirement which limits compatibility, so the logical alternative would be a 5K solution that doesn't require Thunderbolt. Did you decide you don't need the extra pixels, or that dual link DisplayPort 1.2 5K and DisplayPort 1.4 5K had their own compatibility issues?
CoreStoffer
Long story short: To much hassle to use the GC-ALPINE RIDGE workaround on either a PC or HackIntosh. In addition, the BenQ SW271 is a bit better suited to photography since to supports AdobeRGB and have hardware color calibration. I was hoping that there would be some native USB-C/Thunderbolt 3 support for 5K out of a GPU, but the demand is not there outside Mac's.
joevt
[H]Lite
True. Only the BlackMagic eGPU has a Thunderbolt connection to the GPU (ignoring GPUs inside a laptop or desktop) but the GPU is not upgradable and the BlackMagic eGPU requires a Thunderbolt connection to the computer anyway.
jamislike
Sorry for my incorrect usage of 'found', it was me who originally suggested and found this board earlier in this thread, I thought it could be a viable option to solve the USB-C Monitor issue, I just wanted to report back on my progress in case it would be of some use to someone else in my position (Ultrafine 4k + does not have a pci-e slot to spare). Glad you found another solution that works for you, sounds very promising!!
joevt
[H]Lite
You're right. You did first mention the CCG4 evaluation kit in this thread. But in that same post you linked a thread which mentioned the CCG1 development kit nearly a year earlier and the CCG4 chip (not evaluation/development kit). That means you found the CCG4 evaluation kit back in April and finally proved it to be a solution this month. A very good find. As for my solution with the GC-TITAN RIDGE, I have not tried that with a USB-C device that is both USB and DisplayPort. Someone has gotten one LG Ultrafine 4K working with it but could not get two working - and I don't know if they got USB working with it (since USB 2.0 requires separate connections).
TiltError
This thread is fantastic. I have been monitoring it for almost a year.
I have built a portable workstation/gaming desktop pc using the Node 202 case and two Asus MB169C+ USB C monitors. After long hours googling and with the help of this thread, I have managed to get these monitors working in my setup using the add-in card from Gigabyte (GC Alpine Ridge). As mentioned earlier this card only need power to work for my intentions not an actual PCI Express port. As my only PCI express port is occupied by the graphics card, I am using an regular pcie riser that is only connected to molex power and not to an actual pcie port. This is working without issues.
So finally to my question: Im looking to make this setup as portable as possible. The riser and add in card is now outside my case and is quite bulky. Do anybody know some kind of adapter/cable smaller/more compact than my current riser that can power a pcie card from molex power?
My current pcie riser: https://www.gearbest.com/cables-con...nrm9X6FlctTXAiWoMvLfo-zsKeXEtqxxoClasQAvD_BwE
Fun fact: The GC Alpine Ridge provide enough power to charge a Microsoft Surface Go and fast charge mobile phones. You should also be able to get this working on any laptop with displayport by getting a molex power adapter like this one: https://www.quietpc.com/qpc-ac-power-yh-3018 (Not testet).
If anyone plan to do this with a system without display port output it will not work. The GC Alpine ridge will only accept true displayport signals (No hdmi to displayport adapter or similar).
I have attached some images. This whole system can fit in a bag. The cards outside of the case will be put inside a box later, but for now they are out in the open.
joevt
[H]Lite
The risers I used wouldn't allow DisplayPort to USB-C conversion to start unless the riser was connected at least momentarily to a PCIe slot. At the time, I was using GC-ALPINE RIDGE (rev 1.0). Are you using GC-ALPINE RIDGE (rev 2.0)? I have not redone the tests with the GC-TITAN RIDGE.
The riser I tried was this one:
https://www.newegg.ca/Product/Product.aspx?Item=1W7-005H-00013
The IT-GO ADP-099-31 has the same bulkiness (because it is also x16) but it comes with an enclosure which makes things at least neater, and a barrel plug power supply is easier to connect than a molex power supply.
I have an M.2 to PCIe x4 adapter. The length is much shorter because it's x4. I don't know if it will work without an M.2 connection (possibly required for 3.3V?). I'll test it later today. You would probably want a custom built box.
https://www.microsatacables.com/pci-e-1x-4x-card-to-m-2-m-key-4-lane-pcie-slot-adapter
Fun fact: The GC Alpine Ridge provide enough power to charge a Microsoft Surface Go and fast charge mobile phones. You can also get this working on any laptop with displayport by getting a molex power adapter like this one: https://www.quietpc.com/qpc-ac-power-yh-3018.
I haven't tested charging. The GC-ALPINE RIDGE support page says it supports 5V/3A (15W) and 12V/3A (36W). I'm not sure how that works if a PCIe x4 slot is supposed to only support 25W. If it expects a 75W slot (like a graphics card), does it properly reduce capabilities if the slot only provides 25W? Your power supply is 12V/2A (24W) but also has 5V/2A (10W). Maybe that means it can do 34W?
I'm not sure why a HDMI to DisplayPort adapter wouldn't work. I have a few that I can test.
joevt
[H]Lite
I tested the M.2 adapter and retested the x16 riser. Both worked with the GC-ALPINE RIDGE (rev 1.0) (strange, my previous riser test was not successful). Neither worked with the GC-TITAN RIDGE. Both the GC-TITAN RIDGE and GC-ALPINE RIDGE worked in the IT-GO ADP-099-31. These tests were with no connection to a computer's PCIe or M.2 slot.
GC-ALPINE RIDGE in M.2.JPG GC-TITAN and ALPINE RIDGE in IT-GO with M.2 to x4 and x1 to x16 riser.JPG
You might be right. I couldn't get my HDMI 2.0 to DisplayPort 1.2 adapter to work with the GC-ALPINE RIDGE.
TiltError
Thank you for testing the M.2 adapter! This is exactly what I am looking for. I will probably get a M.2 adapter and make my own enclosure with some velcro to stick to the back of my pc case.
Where do you get the molex power from? Maybe the GC-TITAN RIDGE is not working due to not enough power?
I initially thought my GC-Alpine Ridge was broken because I only got one USB C output working. However it turns out if i want both ports working I need to power the card with only one monitor connected to port number 2, then connect the other monitor to port number 1 after boot. If not, port number 2 wont work at all (no power, no display signals). Port number 1 always seems to work. I have testet this in an internal PCIe x16 and with the riser not connected to PCIe and it behaves exactly the same. After I have booted the system in this order i can disconnect and reconnect the ports in any order and they will both work.
Maybe it is something like this you experienced earlier in your testing?
I dont know if I have rev 1.0 or 2.0. I dont have the retail package at hand and cant find the number on the card.
I have to clarify that I am not using the molex power adapter that I linked earlier. I am using molex power from my internal PSU. There seems to be plenty of power for the GC-Alpine Ridge. I can for example power one monitor and at the same time charge my Microsoft Surface Go at speeds exceeding the original wall charger (Original charger 15V/1.6A vs Alpine Ridge 12V/3A).
joevt
[H]Lite
Maybe buy two and try to cut off the extra 10 mm that sticks out behind the GC-ALPINE RIDGE on one of them so your custom case can be that much smaller.
The PCIe backplate of the GC-ALPINE RIDGE extends approximately 12 mm below the M.2 adapter. You can put your power connector in this space below the M.2 adapter. You can turn the 80mm M.2 into a 60mm M.2 by breaking off the extra 20mm if you want to use that room for a side power connector. It looks like the M.2 adapter does not require 5V, so you might consider using a barrel power connector instead which is much easier to connect than molex and might take less space. Create your own barrel to floppy power cable.
https://www.amazon.ca/s/ref=nb_sb_noss?url=search-alias=aps&field-keywords=2.1mm+x+5.5mm+panel
There are many 12V power supplies with a barrel connector. I have some for various external hard drives, Thunderbolt docks and peripherals, and USB hubs. For example, the Anker USB 3.0 SuperSpeed 10-Port Hub comes with a 12V/5A power supply.
It's a similar molex power supply than the one you linked.
https://www.newegg.ca/Product/Product.aspx?Item=N82E16812123309
I initially thought my GC-Alpine Ridge was broken because I only got one USB C output working. However it turns out if i want both ports working I need to power the card with only one monitor connected to port number 2, then connect the other monitor to port number 1 after boot. If not, port number 2 wont work at all (no power, no display signals). Port number 1 always seems to work. I have testet this in an internal PCIe x16 and with the riser not connected to PCIe and it behaves exactly the same. After I have booted the system in this order i can disconnect end reconnect the ports in any order and they will both work.
Maybe. There's some flakiness involved but I would not have expected that from an internal PCIe x16 slot.
I asked because you got yours to work in a riser and I didn't, but now I did so it probably doesn't seem to matter.
It's not possible for the GC-ALPINE RIDGE to tell the difference where the power is coming from. I assume/hope the power supply would just stop if there wasn't enough power.
FloMac
Did anyone here try the Moshi USB-C to DisplayPort cable yet? It claims to be bi-directional, so it ought to work. If it works it is the least expensive option by a fair margin.
I just tried it. Together with an USB 2 into USB-C injection cable. I tested my self-made cable putting it in between the LG UltraFine 4k and the USB cable to the MacBook while connecting the USB 2.0 A cabled via my Dock. This way the UltraFine worked, fine. However upon replacing the USB-C cable with the Moshi one the monitor refused to do anything at all although its' internal HUB and the connected disk drive showed up in the system.
To resume: The Moshi bi-directional DisplayPort cable does not work with the LG UltraFine.
joevt
[H]Lite
It is unclear to me from the picture how that cable works. Are those USB-C female or male connectors? Is the USB 2.0 connected to only one of those connectors or both? What other cable or whatever is used to connect this to the MacBook. What MacBook are you using?
I guess the Moshi cable doesn't work with the LG UltraFine 4K because the cable is not bi-directional or because it doesn't have USB? The Moshi cable might work (if it's bidirectional) with the LG 34WK95U-W because there is a separate USB input?
FloMac
The frontmost plug is a male one, while the other one is female.
It's only connected upstream -> to the male plug (to avoid struggles) – Also, compliant with the USB-C specification, it is only connected to one pair of D+, D- lanes (A-Side, although it does not really matter).
Additionally I'm using the mentioned Moshi-Cable, which is actually the only bi-directional one, that I'm aware of. So the non-working connection looks like this:
  • MacBook Pro (15", 2017) -->
  • Aorus Gaming Box (refitted with AMD RX Vega 56 nano) -->
  • Moshi bi-directional USB-C – DP-cable -->
  • custom passive USB-C PCB (which also connects to the MacBook/Gaming Box via USB-A) -->
  • LG Ultrafine 4k
However I confirmed, that my custom USB-cable works like so:
  • LG Ultrafine 4k OEM USB-C cable -->
  • custom passive USB-C PCB (which also connects to the MacBook "directly" via USB-A) -->
  • LG Ultrafine 4k
Nope.
Possibly…? Though this has nothing to do with the additional USB, but rather with how the hardware works internally. No way to test.
BTW.: My custom cable actually does exactly the same as the modded cable on one of the previous pages, only omitting the need to cut one of those unproportionally expansive USB-C cables.
joevt
[H]Lite
The Moshi cable seems kind of useless in the DisplayPort to USB-C direction if every USB-C display needs a USB connection to also exist in the USB-C cable. It seems that the LG 34WK95U-W has the same problem as the LG UltraFine 4K even with its ability to choose a different USB input.
Maybe Apple will release a Thunderbolt display where the Moshi cable can be used (for non-Thunderbolt computers).
joevt
[H]Lite
The M.2 to PCIe x4 adapter uses a "1084-33" voltage regulator. It uses 5V to generate the 3.3V required by the PCIe x4 slot. 12V is used directly by the PCIe x4 slot.
joevt
[H]Lite
This is what I did to make my LG Ultrafine 4K's USB work. Brightness control, speakers and USB-Hub works. The only thing that does not is firmware update. I cut open a USB-C cable stripped the green and white USB data pins. The same with a USB cable with type A connector. Then solder both together.
Instead of making your own cable, there is one from made by Huawei for the Huawei VR 2
https://www.ebay.com/itm/Original-Huawei-VR-2-Computer-Connection-Cable-DP1-2-USB2-0-to-Type-C-Cable-/253947777674
The cable is only good for four lane DisplayPort 1.2 with USB 2.0 over USB-C devices like the LG UltraFine 4K. It is not good for devices that use two lane DisplayPort 1.2 with USB 3.0 (USB-C docks and some lower resolution USB-C displays) or Thunderbolt.
zambetti
Just stumbled on this great thread, been looking to connect an Ultrafine 4K to DisplayPort.
Perhaps this board with USB power injection might suffice as a compact solution to drive the Ultrafine 4K?
http://www.ti.com/tool/TIDA-01620
"Supports VESA DisplayPort Alt Mode to USB-C"
Also found this promising cable (below) and wrote to the supplier, but I haven't found a distributor yet.
http://www.simya-tech.com/vr-cable/simya-custom-dp-usb-type-c-ultra-slim-coaxial.html#
In the meantime, I'll follow the suggestion above and give the Huawei cable a shot, fingers crossed.
joevt
[H]Lite
The TIDA doesn't seem much different than the Moshi bi-directional cable. Probably not sufficient (it doesn't have USB for one thing).
The Simya cable looks like the Huawei cable. I think they're both from China so either one will take a few weeks to ship to North America.
joevt
[H]Lite
Hello from the USB C Hardware subreddit.
Ps. As I noted on reddit too but since it's inlined so most of you won't click, adding HDMI: if you don't want to pay the StarTech hype tax, https://www.amazon.com/Cable-Matters-DisplayPort-Adapter-Supporting/dp/B00JQORLCG this is cheaper and 4.5 stars reviewed.
Good find on that USB-C adapter. Would be interesting to compare with the Moshi bi-directional DisplayPort 1.4 to USB-C cable and the Huawei VR 2 cable. If that adapter is using the Cypress chipset, then why doesn't it include the USB input?
People have been able to use the Moshi cable to get 4K with the newly released LG UltraFine 5K display (the display accepts both USB-C (4K DisplayPort Alt Mode) and Thunderbolt (dual link DisplayPort 1.2) input).
The Huawei VR2 also includes USB 2.0 making it a better solution for the LG UltraFine 4K (the Moshi doesn't work) and probably the new USB-C capable LG UltraFine 5K.
HDMI 2.0 to DisplayPort adapters are available but cost $200, much more than the HDMI 1.4 to DisplayPort adapters. There's a discussion at https://insights.club-3d.com/thread/hdmi-2-0-to-displayport-1-2-2/6/
TL;DR
Step 1: Buy WACOM Link Plus.
Step 2: ….
Step 3: It works.
Hello Guys,
Sorry to resurrect this thread, but first of I'd like to thank you all for giving me insight into a topic that I found was harder to deal with, than expected.
My Story:
I bought an used ASUS MB169C+ for cheap. But only then I found out why this guy had sold it. (Yeah should have looked up specs before, but it didn't cost me more than 30 bucks.)
So I read through countless forumposts and topics and finally arrived here. At first I considered buying a developer kit, but figured out it was not worth the money or the trouble. Then the Alpine Ridge Card. Too bulky for my use case and also costly with the needed accessories.
And then I found the WACOM Link Plus. At first I mistook it for the first version, which reportedly didn't work, because there is no powerdelivery. But this new Version features powerdelivery. So I pulled the trigger. And...
It works!
You can find it here: https://us-store.wacom.com/Product/wacom-link-plus-for-wacom-cintiq-pro-13-and-16#/undefined1
I just had to use a USB-A -> USB-C cable from my smartphone for the power in, because that is not included. But I couldn't care less. Still, there are some slight issues, I've encountered so far.
Known Issues:
- Sometimes the monitor gets no signal when plugged in while the computer is powered on. Workaround: Plugging in HDMI first and than the USB-C Powerconnection and turning monitor on and off again.
- No USB-A to Type C and full DisplayPort cable included. (only USB-C -> USB-C, MiniDP, USB-A -> Micro-USB)
Unknown at this point:
- Is there sound delivery? (Probably not.)
- Does this work with 4k-Monitors or higher refresh rates? (I only use it with 1080p/60hz.)
Maybe someone is willing to try this out and test this.
Regards,
AnotherBrother
(Sorry for wall of text and Grammar. English is not my first language, but you might have noticed at that Point.)
joevt
[H]Lite
The power input is USB-C? So we need a USB-C power supply?
USB-A to Type C is for power input? But USB-A doesn't have all the power delivery features of USB-C? Maybe should use a Power Delivery sniffer to see what's up. What is the power supply output for a Cintiq? One person said the power supply of the Cintiq would not supply power through the power input of the Link. This means the power input is optional if the display has its own power supply.
The HDMI input is only HDMI 1.4. The input means there must be an included HDMI 1.4 to DisplayPort converter chip. HDMI 2.0 conversion would increase the size and cost greatly.
HDMI 1.4 can only support 1440p 60Hz, or 4K30Hz.
There must be. Sound can be delivered through USB or DisplayPort. The adapter does not change the USB or DisplayPort signals. I don't know if the HDMI converter also converts audio to DisplayPort. I think most converters do.
The product page says yes. 4K60Hz. It says in that mode, USB is restricted to USB 2.0. DisplayPort 1.2 requires all 4 lanes for 4K60Hz, so there is no superspeed lanes remaining for USB 3.x.
My questions are:
1) Can this provide a USB-C DisplayPort alt mode with two lanes of DisplayPort and USB 3.x? Connecting a USB-C dock would be a good test because they usually use that mode (2 lanes DisplayPort + USB 3.x). Actually, your display, the ASUS MB169C+, has USB 3.0 ports so you could at least test for DisplayPort 1.2 two lane + USB 3.0 mode.
2) DisplayPort 1.4?
3) USB 3.1 gen 2? I have a HP Thunderbolt Dock G2 that can test #1, #2, and #3. The answer is probably no for #2,#3 - because I couldn't find a Cypress chipset that allowed them. They could use a different chipset but Wacom doesn't require more than DisplayPort 1.2 or USB 2.0.
4) Power Delivery input options? We only know that input is optional. You were able to get power in from a USB-A to USB-C charging cable (I assume your phone is USB-C and your phone charger is USB-A? Was the USB-A end connected to the charger or your computer?).
5) Power Delivery output options? Is this a copy of the input options? Maybe, if the input is connected. But input is optional.
I guess I'll buy one to check it out.
Hello joevt,
Thank you for answering my first Questions. This sheds some light into the specs.
Regarding the powerdelivery I plug in the USB-A -> USB-C cable directly into my PC. No dedicated power supply is used. That's why, because I have read that the Asus MB169C+ only needs ~6w and the lowest phone charger I have delivers 15w. So I was afraid to fry my newly bought adapter. I noticed that it doesn't matter if I plug it into USB 3.0 or 3.1 Type A, as both deliver enough power.
And regarding:
I'm unable to confirm this. My assumption: as this is labelled "Plus" I think it's just an advanced version of the original Wacom Link. As specified on the product page, it's meant to be a "one cable solution for the Wacom Cintiq" but I don't see a reason that it shouldn't work without a power-in cable used.
But I'm not sure what you meant with:
1) Actually, your display, the ASUS MB169C+, has USB 3.0 ports so you could at least test for DisplayPort 1.2 two lane + USB 3.0 mode.
This Display only offers a single USB-C Connection and that is why this quest started for me. Perhaps you could clarify what you meant by saying that. (Maybe it's just my language barrier.) Anyways I currently have no working DP cable, so during my tests I only utilised HDMI.
Excited to here more from you and others who are willing to take the chance.
Good luck and regards,
AnotherBrother
joevt
[H]Lite
I've seen videos where the power input of the Wacom Link Plus is not used.
I read in the specs for the ASUS MB169C+ a line that says "USB Port(s) : 3.0". After looking at the manual, I see that there is only the USB-C port. Does the "ASUS MB169C+" appear in Device Manager as a USB device connected to a USB controller in your laptop? Or does it only appear as a display connected to the GPU of your laptop?
When plugged in, the monitor is listed under it's actual name at first. But after a second it splits into a generic "PnP-monitor" device and an unknown "USB BillBoard Device". When first plugging it in there's also a notification saying that this device might not work with its full resolution. But one can ignore this as it works fine other than that message.
joevt
[H]Lite
Billboard devices are normal with USB-C devices. They're always USB 2.0. The billboard device will tell you if you connect a USB-C device that wants DisplayPort or Thunderbolt alt modes to a USB-C port that only supports USB for example.
joevt
[H]Lite
I saw this BizLink VirtualLink™ Interface Adapter
https://www.bizlinktech.com/products/detail/1332/VirtualLink™+Interface+Adapter
I don't know if it really exists or how to buy it though.
It supports all the DisplayPort alt modes: DP HBR3 x 2 + USB 3.1 gen 2 + USB 2.0 and DP HBR3 x 4 + USB 2.0.
plus the new VirtualLink alt mode: DP HBR3 x 4 + USB 3.1 Gen 2
plus power delivery up to 27W
VirtualLink might be dead, but the DisplayPort alt modes would be useful.
joevt
[H]Lite
I did some testing with a Wacom Link Plus. I got it to work with USB-C to HDMI 2.0 (4 lane HBR2) and USB-C to VGA (2 lane HBR2) and USB-C to DisplayPort cable (4 lane HBR2).
It is of course limited to USB 2.0 speeds because the USB input is only USB 2.0 Micro-B (4 conductors on both the USB-A and USB Micro-B end).
It requires at least USB-A power to function (connected to the USB-C power input).
The HDMI input works unreliably. It either gives a picture or black. When it's black, it is correctly sending horizontal and vertical sync signals at the expected rates.
The included USB-C cable works well as a USB 3.1 gen 2 cable (1000 MB/s from a USB-C NVMe drive).
It would not work with a HP Thunderbolt Dock G2 connected to the USB-C output - probably because the HP requires USB 3.x + 2 lanes of DisplayPort and the Wacom only provides USB 2.0 + 4 lanes of DisplayPort.
I could not get DisplayPort 1.4 to pass through the Wacom. I may need better cables or (a simpler DisplayPort 1.4 sync because the HP Thunderbolt Dock G2 is too complicated), but it's more likely not a supported mode of the Wacom. My test was:
1) Prove DisplayPort 1.4 works by using HP Thunderbolt Dock G2 to drive Dell UP2715K at 5K60 from a single DisplayPort 1.4 connection. The source signal for the HP Thunderbolt Dock G2 is a GTX 1070 connected to a GC-TITAN RIDGE Thunderbolt 3 add-in card with one DisplayPort cable. This works good - The HP Thunderbolt Dock G2 has a DisplayPort 1.4 MST hub that can take two streams over a DisplayPort 1.4 connection (transported over Thunderbolt 3) and output two DisplayPort 1.2 signals (2560x2880 60Hz) to achieve 5K60.
2) Insert Wacom into the source. This fails as it cannot transmit DisplayPort 1.4.
Edited: removed comment about moshi cable not working as output from the Wacom - it does work. Added more info about DisplayPort 1.4 test.
Lanky0
I read through this thread but still couldn't find a solution for the issue i'm facing (perhaps there was but i am not fully understanding some USB-C tech situations)
I have a xiaomi mi notebook pro (16GB, i7 version) and i bought the Asus MB169C+. The notebook pro has 2 USB-C ports, however only 1 can be used to charge the device (PD). If i plug the asus screen into that port it works but i cannot charge my laptop at the same time. I also tried the official xiaomi USB hub that has multiple USB-C connectors but it would only let me charge the laptop through it, not plug the screen in as well.
Before i try selling it on ebay, is there any other possible way I can get the screen working + charge my laptop at the same time? Perhaps using some adapter for a workaround
I'm now looking at USB-A portable screens so it will free up the power delivery USB-C on my notebook pro - https://www.asus.com/uk/Monitors/MB16AC/
