Use own modem and router for AT&T Uverse?
Discussion in 'Networking & Security' started by DarkDubzs, Jun 5, 2014.
  1. DarkDubzs
    DarkDubzs Limp Gawd
    354
    Jan 3, 2014
    Today i got AT&T U-Verse internet and i got the standard in home install... with the typical modem/router combo "gateway." I want to soon use my own modem and router. Would it be possible to do that, use my own modem and router? They would be a Zoom 5341J modem and a TP-LINK TL-WDR3500 router. I notice that there is no coax cable right now, instead, the tech plugged an RJ-11 cable into the gateway instead of what i imagine would be a coax for WAN input, so would i use an RJ-11 to Coax adapter or get a tech to come out and run a coax line for me? Even then, if i had all the cables and the modem and router, would it work... or am i forced to use AT&T's cheap gear?
  2. jmilcher
    jmilcher [H]ardness Supreme
    4,109
    Feb 3, 2008
    Uverse uses DSL... At least mine did. It is not a cable modem like the zoom you mentioned.. At least if its the same u verse I had. You can generally tell by the connection speed.
  3. DarkDubzs
    DarkDubzs Limp Gawd
    354
    Jan 3, 2014
    DSL... thats even worse than the problem im having right now trying to use my own gear.
  4. JTY
    JTY 2[H]4U
    2,291
    Aug 4, 2002
    You should be able to use your own modem. But, you'll need to determine if your line is ADSL2 or VDSL. Then pick up an appropriate modem.
  5. gangolfus
    gangolfus Gawd
    905
    Aug 8, 2005
    You should be able to set the gateway to bridge mode then use your own router. What is your end goal here? What are you trying to do that you want to use your own equipment?
  6. DarkDubzs
    DarkDubzs Limp Gawd
    354
    Jan 3, 2014
    I wanted to use a third party modem and router to try and get the bets performance i can for what im paying for, because im sure its no secret that the standard modem/router combo gateway that is issued by the ISP isnt the best thing to use.
  7. jmilcher
    4,109
    Feb 3, 2008
    The modem will get no better. You will see zero performance increase on a DSL connection.
    You can however improve the WiFi router by using your own and bridging the gateway as mentioned earlier.
  8. Muegen
    Muegen n00b
    41
    Dec 6, 2012
    Actually wrote you an answer in your other thread.
  9. ktr
    ktr Limp Gawd
    162
    Apr 27, 2010
    Not sure where you got that information, but it is not true. Considering the customer is the one paying for the equipment, ISPs will use reliable, hassle free hardware that will guarantee their advertised speeds.
    And 3Mbps is hardly pushing it in these days. Heck, it is not even considered broadband based on FCC definition (which is 4Mbps, soon to be 6Mbps).
  10. DarkDubzs
    DarkDubzs Limp Gawd
    354
    Jan 3, 2014
    Im thinking of doing that now.
