I'm getting ready to setup a security system with 12 cameras and would like to know what the best solution to drive 2 32" monitors on separate floors. Here is what I would like to do:
The source PC will be located in a server rack on the 1st floor driving the 32" monitor on the second floor (~300 ft away) and another 32" monitor on 4th floor (~500 ft away).
These are the cameras I am using:
AXIS Q6035-E POE PTZ
HDTV 1080p 25/30 fps as well as
HDTV 720p 50/60 fps
Would some type of VGA Baluns over cat5/cate5e/cat6 work in my situation? If so, what brand do you recommend? I currently don't have a budget, but would like to keep the baluns or extenders under 1k.
Configuration Setup
12 Axis POE cameras> Gigabit Switch> Network Video Recorder (Server)> source PC driving 2 32" LCDS.
Thanks in Advance!
HDTV 720p 50/60 fps
Configuration Setup
Thanks in Advance!
