IrishRangerWingMedic
- Feb 5, 2007
Hello All,
I have major trouble with my USB devices and Vista 64.
I have my Saitek Eclipse II keyboard and Logitech G5 mouse which work perfectly. The only problem is that Vista keeps asking for drivers when I start Windows. If I select the "Don't Ask Again", Vista disables them (not good).
I have to "Ask Again Later" option to continue on.
My USB midi controllers (Music keyboards) just won't work at all. Windows asks for drivers, which I point to (Novation 64 bit drivers), but Vista will not install it.
I just got a new HP LJ1022 today, and tried to install the beta drivers for Vista 64(corrupt zip file on site anyone got a valid set? - will not install). Using HP online tech support I was trying to manually install by adding printer, local orinter, existing port but could not choose usb001 as it did not exist....
Support recommended i uninstall all usb controllers from the device manager. I got about 2 done and then mouse and keyboard were disabled (which makes sense). Anywho, I rebooted and Vista asked for drivers for USB controller, which it could not find, or locate in the intel folder (I just installed the lastest intel usb controller drivers) I did the suicidal Do Not Ask Again, and bang - no keyboard or mouse at all. Even Safe Mode no mouse or keyboard. I had to recover from the Vista Installation disc.
It would seem that Vista is not letting me install any new USB devices, and if I uninstall any previously installed devices, then they can't be installed again - What the hell is going on????
My BIOS (recently updated) settings all seem fine. I tried to change to O/S Plug'n'Play On but this makes no difference.
http://www.snapdrive.net/files/490394/Saitek.jpg
Sorry for the long rant.
