I suspect this is a usb 5v current issue, but I'm not sure. It happens only on certain drives attached to certain computers. They click away when plugged in, failing to start up, and may register in windows as a malfunctioning device. But the errant drive will work fine when plugged into another computer.
This is even with the usb y-cable that supposedly gives 1A.
Any ideas?
Also, does anyone know for certain the exact power jack these drives use? is it 3.5mm x 1.35mm ? there's also x 1.5mm.
Any ideas?
