USB-C Cable Arcing on Disconnect
Nobu
I have an Anker USB-C cable which is hooked up to my PC for charging/data transfer. I noticed that when I disconnect it, it arcs inside the cable's connector end several times (about 5 on average, in quick bursts).
Is this normal/expected behavior?
UltraTaco
Haven't seen that before. May be ground faulty? Too much wet dust shorting out?
vegeta535
No it is not. Make sure your outlet is properly grounded. I had a outlet ground go bad and anything metal I touched on my computer shocked me. Even my keyboard which was connected via USB and made of metal.
Nobu
Cool. Outlet is fine, my power supply has no ground wire though. I grounded the psu chassis, but I guess that wasn't enough. Going to have to investigate further.
somebrains
I had to have my gfs pixel 1 charging port replaced when a cable shorted a couple years ago.
Melted the cable end, burnt the charging nub thing in the phone into the shape of a dorito.
Nobu
Wait, what?
Power supply: rps-200-12-c
See the datasheet for details. The input header has only two pins, for line and neutral (no ground). There is a ground symbol embossed in the chassis of the power supply, so that's what I grounded to the case. But either that's not enough or my ground isn't good, so I need to investigate further.
The case is grounded via the ground pin on the three-prong cable. The cable connector came with the original power supply, and is grounded via the screws...maybe. I need to check that. Gotta go hunt down my multimeter.
lopoetve
Power supply: https://www.mouser.com/ProductDetail/mean-well/rps-200-12-c/
Link doesn’t work on my phone. Wtf kind of system is this?
lopoetve
doesn't work on the PC either, but I was able to find it with some googling. Industrial setup of some kind?
Nobu
Sorry, must've mangled the url. Edited link in post.
No, not industrial. I'm using a one2 DC-DC power supply, with the meanwell RPS-200 converting AC to 12V DC. Have a thread in SFF subforum. It's not as compact as I had hoped, but it does reduce cable clutter in the case a lot.
Lots of builds on [sff].net using a similar setup, but I haven't seen them complain of this specific issue. Don't know if they just haven't noticed, don't care, or they actually know what they're doing. lol
Edit: The thread.
lopoetve
oooohhhh. I did a bunch of micro servers using picoPSUs, so now it makes sense. Didn't think about the step between a pico and a actual normal SFF ATX style one. Now that makes sense. Picos I used had a ground from the power brick (think like a laptop) though.
