BrainEater
- Jul 21, 2004
I wonder if they work on shiny aircraft?
Shiny only matters below 1Mw/cm2.....
Let's see a real laser.
Targets with ablative heatshields (anything hypersonic) are far, far harder to hurt with a laser though. I know of ceramic coatings that are 99.9-99.8% diffuse. You ain't doing shit to that even with hundreds of kilowatts when your engagement time is a second or two.Remember no mirror is perfect. At the energy levels involved even a few percent of the beams power is enough to burn off the outmost reflective surface at which point the target is no different than any other lump of plastic or metal being slagged down.
As all public news about military hardware is about 15 years behind what they actually have today,Shiny only matters below 1Mw/cm2.....
Its been twenty years with no repeated attempts. Maybe they can be used to stop a second Covid?
Limited by visibility mostly as scatter will increase significantly beyond visible range. So on a normal day (edit I forgot to complete this lol) 10-20km at sea, sometimes far more if you can see horizon. Basically, attack your target in the fog and their lasers is useless unless it's a magical 94GHz laser (almost like xrays). They can penetrate through the 'optical window' of water vapour practically unhindered.What's the effective range of a laser? I thought it was only a couple of miles in good weather.
Not really too far off actually, they're pretty close to what is publicly available, 5-8 years delay if any. Really though you need years of R&D to combine the off-shelf components properly but so far word on the street is 20kW single mode from the leading manufacturer (this was told to me last year by one of the employees). Combine 7-8 of them to a single beam and you have a laser weapon source. Next fun part is adaptive optics if you want to do anything beyond 5-10km..As all public news about military hardware is about 15 years behind what they actually have today,
you will get your lasers in about X--X years.
Unless you mean the colored star wars 'lasers"
yea we don't do that.
150kW out might be absolute worst case (older tech) max input power 550kW (CW especially high beam quality is typically lower efficiency) but there are more efficient ytterbium fibre lasers than that (some are 60%-80% but lower beam quality). Sorry bit rusty on my ytterbium non-doubled fibre laser efficiency numbers and they are usually CW, so maybe another 220kW for cooling. They have options for reservoir approaches though, larger chillers use more juice so depends which way you go. All up 800kW for a 1 second shot plus continuous cooling and pump requirements after shot.
They use DI water to cool fibre laser pump sources due to galvanic corrosion. You could heat exchange with salt water BUT these laser sources typically have temperature tolerances within 7°C range. When you go outside of that you can get thermal and laser beam quality issues, even worse is going below dew point.. big problem. If that sea is too hot (or cold and you can't adjust for it properly) you could have issues. But I agree otherwise - my solution would be a large reservoir kept at temperature.. then you don't need all the cooling. That said on a ship the package size and weight isn't as much of an issue. On an aircraft, it's totally different. But also easier to heat exchange with cold air outside.Why would you need all that extra power for cooling on a ship? Just use the ocean water to cool it. No need for a massively powerful phase-change system when you can just pump the ocean water though it to cool it.
Don't need to shoot bats, shoot the people getting together when you're supposed to be sheltering in place. They're the real reason this shit has gone on so long, everyone stays inside for 3 weeks and bingo bango no more cases. Meanwhile into month 2 and the main reason we are opening up is economic not healthHow accurate are these at shooting down bats?
Looks like these naval lasers just met another milestone in reaching operational status with a live fire test in the Pacific.
https://www.businessinsider.com/us-navy-ship-destroys-drone-with-laser-weapon-2020-5
This could be used to stop a second 9/11.
But at what cost?
I'm wondering if it's actually a cost savings measure.
How much does each SAM cost?
A shitton, and these laser firings only cost like 30 cents in energy.
3. Is not a problem.The benefits of the laser over interceptor missiles are many. Recognize this was a proof-of-concept. The goal would be much lower dwell times for target destruction. (More powerful laser source, tighter beams, intelligent aiming for weakspots.)
1. Ships carry missiles in VLS. Once fired, that cell is empty until the ship returns to port. A larger vessel carries ~64 missiles. These are split between anti-air, anti-ship, and cruise missiles.
2. Related: ships only have so many anti-air missiles. If it carries 28, then the 29th missile gets through.
3. Hypersonic inbound missiles are VERY difficult to intercept. To physically get an anti-air missile up and to the hypersonic inbound missile's location before it hits the ship (or whatever that ship is protecting) is a VERY difficult proposition. Lasers don't have that limitation. This is the main driver pushing directed energy weapons on ships.
4. Engagement time can be greatly reduced (if the delivered energy can be increased). Pulse, slew to the next target, pulse, repeat as needed...
5. Cost per round. A gallon of diesel vs. millions.
6. Signature issues: ever see the poison gasses come off a missile launch? A snap-shot with sailors on deck would produce casualties. Not so with lasers.
7. A technique to engage targets is shoot, look, shoot. Meaning, fire an anti-air missile. Did it hit? If not, fire a second one. That technique is risky. A better technique would be shoot, shoot, look, shoot. Fire 2 missiles (assume an 85% probability of intercept and do the math), look, fire a finisher if needed. This would deplete the limited magazines even faster. Lasers just shoot as needed.
You dont really have to worry about that even shooting it with land behind the target. The laser will dissipate due to loss of beam coherency over distance and not really do any damage.As long as you shoot the laser up, you don't have to worry about where the spent laser will land, unlike a traditional SAM.
China already has production on an exact copy of our latest fighter craft. Nothing "poor state" about it. China is fully capable of producing everything they are able to steal.Rizen speaks the truth. Russia and China both have been stealing military tech from the US and other countries for decades and decades...but look at the poor state of their militaries technologies.
They are great at making a small number of flashy and neat proof of concepts to puff their chests up to the world, but they done have the financial or technological capabilities to enter them into mass deployment.
Yes, this is a serious issue.How well would it work in less optimal weather conditions?
Two reasons, the first being as you said, liability. The second is you cannot sell a powerful enough laser on an open market to regular consumers, it is illegal. You are free to build powerful lasers yourself, they just cant be sold without special permits.A little while ago I started wondering if it would be possible to build a small laser system for killing mosquitoes. Well, it appears I was not the first person to think of this, but there still isn't one on the market. If there were, I would buy one in a second.
But what I could not tell from the articles I read is why there are none on the market. The only thing that makes sense to me would be the liability issues of shooting someone in the eye. ??
For example, Australia bans the use of any laser devices with power more than 1 mW.
In Europe and the UK, due to the rising number of laser attacks in recent years, the power limit for lasers sold legally was downgraded from 5 mW to just 1 mW.
In the US, it’s completely legal to own lasers of any power and any class as long as they’re FDA compliant. This means that the laser product has to pass certain criteria like having an interlock switch, reliable safety features, and quality control.
However, it’s illegal to sell laser products with a power greater than 5 mW while being branded as “laser pointer” or marketed for pointing purposes. Such devices are considered by law to be non-compliant or illegally labeled.
It’s worth noting though that the regulations prohibit selling them but not owning them. It’s also important to check the local laws as they vary between states.
Despite the fact that laws and regulations concerning the safety of laser devices differ between countries, there are some rules that exist in almost every country in the world.
Such global illegal offenses include pointing a laser beam at vehicles on the road or passing aircraft which could cause damage to the driver or the pilot’s eyes and endanger the plane.
In the US, this crime is punishable by up to five years in federal prison and a fine up to a few hundred thousand dollars, according to the law signed by President Obama on the 14th of February 2012. A similar law is also enforced in the UK.
Shining a laser light at a police officer or a law enforcement official is also considered a criminal offense in many places.
Obviously there are other costs. Equally obvious, I was discussing the cost per engagement, not the fielding cost or the development costs.
I did not include the costs of developing phased-array illumination radars or how to gimbal a seeker in a missile or...etc.
This technology is a game-changer. Ask a Revolutionary War soldier how much is too much to spend for a working belt-fed machinegun.
As always with new tech, the devil is in the details. Seeing it develop under field trials will determine whether or not it will be of sufficient utility to be fielded.
In 1998 I went to NROTC CORTRAMID. We spent a couple days on an Aegis Destroyer. IIRC, they said a fully manned Aegis Destroyer, at that time, could defend itself against 24 simultaneous incoming missiles, or 8 simultaneous incoming missiles in a fully automated mode with no sailors aboard. This capability with defensive missiles that would intercept incoming hostile missiles in flight. With computer based guidance systems that did everything automatically.
I’m sure the capability has only improved in 20+ years.
That capability not even considering the Phalanx guns which could automatically track and shoot down things as small as Seagulls. They were to shoot down any incoming threat in closer proximity to the Destroyer with a continuous stream of bullets. (Be it missile or plane).
The problem with existing tech was not capability but capacity! Defense Missiles and Phalanx rounds run out. A nuclear powered ship’s lazer weapon would be almost endless.
You have “unlimited” sea water to cool it.Except cost per engagement INCLUDES all those other costs. Ignoring that is silly. We need to look at the total cost of ownership of any device. Be it a cool new shark with a laser on its head or a brand new super computer.
Phalanx is capable of shooting down things much smaller than seagulls. Also a nuclear power ships laser weapon would not be almost endless you would still have to worry about heat dissipation. You might not run out of "bullets" but you still remain limited in how fast and often you can fire it. Also there is a problem of charging. Does the reactor push enough power for eveything onboard AND firing a high energy weapon? Maybe. Or will it need capacitors to "recharge"?
sure you can. a buck o' five.
Hopefully, there are some folks here (and out there) that aren't nieve enough to believe that this "public" announcement is anywhere near the full extent of the US's progress in this field...
In 99.9999% of all public disclosures about military tech advancements, whatever you hear about in the news today, is actually about 5 years behind what they have actually accomplished behind the scenes...
In other words, we have had the ability to shoot down incoming aircraft, missles, rockets, satellites etc at will for quite some time now....with ever increasing accuracy & destructive powers, it's just been very tightly locked down and kept out of public & enemy view, making it harder for them to steal/duplicate the tech...
This is just anutha case of what was once thought of as purely science fiction becoming a reality faster than most people thought possible
If you wanted to kill a mosquito or fly "instantly" as you hit it with a laser beam you would probably need a 10-20 watt laser, which is drastically outside the limit of what you can sell in any country and would also cause blindness in a human if you hit them in the eyes and so you have a major issue there. The device would also be somewhat large, to have a proper power supply and transformer, and the necessary cooling on your laser.
