urgent striker question for vsb
sd11
PC probe is reading 1.74... I have it set to auto
Is this a bad value, or is something bogus on PC probes fault.
The copper heat pipes feel hot as hell, but that's been normal.
leeghoofd
What setting is it set in the bios ? it always overvolts that's normal, but I have the same reading in everest as in Asus probe... if I set 1.5 for SB it goes from 1.5-1.6 same for CPU VTT if I set this at 1.45 it values change from 1.45-1.6 all the time... NB and 1.2 HT stay pretty constant...
Try eg Everest Home and refresh a few times see if that gives also erratic readings... for ya heatsink make sure there's some good airflow in the case and even better directly onto the NB at least...
