verklighet
- Dec 31, 2008
Hey Guys,
I have this new computer that I've used for about 2 weeks. Everything went fine until I had my first few bluescreenofdeath (in separate occasions). I researched online for a while and realized it might be because of drivers for a Wifi Card that I had inserted. So when I restarted Windows to make one last check that everything else was fine before i removed the Wifi card, so I ran CPUID and SPEEDFAN just when Windows started up.
Right then and there BOTH my monitors went BRIGHT RED (!!) and the computer froze. I couldnt ctrl+alt+del, nor could I reboot computer with a simple press of the Power button, I had to press and hold it until it turned off.
I've never experienced a RED SCREEN like this. It was quite intimidating to be honest.
Has anyone had any experience with this? I really need help to understand this so that I can return the computer and explain to them what the problem might be.
Heres my build:
Motherboard: ASUS P8Z68-V PRO/GEN3
CPU: Intel Core i7 3770K - Unlocked - Ivy Bridge
GPU: Gigabyte GeForce GTX 680 2GB OC Windforce
RAM: Corsair Vengeance 16GB (2x8192MB) 1600Mhz
HDD: Samsung 830 Series 2,5" SSD 256GB - Desktop Edition and Western Digital Caviar Black 2TB 64MB
Cooling system: Corsair Cooling Hydro H100
Power Supply: Corsair HX 850W
OS: Windows 7 Home Edition
Please help, if you need anymore information I'll keep this updated.
Thanks in advance guys
Heres my build:
